First post, by tanz
I've searched all the millions of stonekeep postings and I still can't figure this out. 😠
This is what I run in DosBox .63
I installed Stonekeep from the cd.
Stonekeep is in C:\INTRPLAY\STONKEEP
mount "c" "c:\" -ioctl
mount "d" "e:\" -t cdrom -usecd 1 -ioctl
I get the error of Illegal command: E:\data.SK.exe
I also tried it in D-Fend v2. I get the same error. When I use DFend w/ the setup.exe found in C:\INTRPLAY\STONKEEP, I can run the setup and test the sound. So I'm guessing I'm pointing incorrectly to the cd or mounting the cd wrong. Any ways to fix?
BTW its the same error as this guy:
Stonekeep
I could send someone my D-Fend profile for Stonekeep cause VOGONS wont let me attach the .dfe file.
Thanks in advance.
--tanz 😢
