First post, by boggsman
Sadly my Gateway Jabil Kadoka motherboard died recently. I was having trouble finding a replacement for a reasonable price, so I sprung for the FIC/Compaq ASPEN2/ASPEN3. Here are the specs:
AMD Athlon 900MHz 512KB Orion
AMD 751 / VIA 686A chipset
256MB Micron PC100 2-2-2
IBM Deskstar 40GB 7200rpm ATA100
3Dfx Voodoo3 3000 AGP
Sound Blaster Live! CT4830
DEC 21140-based 10/100 NIC
NEC USB 2.0 PCI card
Windows ME
Super Bypass Enabled
Reply 2 of 13, by boggsman
Bruno128 wrote on 2024-03-08, 05:49:
Nice! PCI USB 2.0 cards in Win98 are performance killers though.
The only reason I'm using it is because this machine won't get past the bios with my USB KVM plugged in. I got tired of unplugging it so it would boot.
Reply 4 of 13, by boggsman
Bruno128 wrote on 2024-03-08, 11:49:
I wonder if same happens with bios usb keyboard emulation disabled. But yeah that’s very irritating indeed. To avoid those troubles I’m using a hybrid usb-ps/2 KVM.
How does that work? So you have a USB keyboard and mouse and it converts that to PS/2? Or is the other way around?
Reply 6 of 13, by boggsman
Sisoft Sandra Benchmarks
Reply 7 of 13, by boggsman
3dmark
Reply 8 of 13, by boggsman
My Voodoo3 3400 😆
Reply 9 of 13, by boggsman
I just installed the NEC USB 2.0 card. 3dMark2000 score without the card was 3209. With the card installed and my KVM connected: 3208. So virtually no difference 🤷‍♂️
I'm happy about that 😎
Reply 10 of 13, by melbar
Very nice, clean board with less capacitors to replace!
boggsman wrote on 2024-03-11, 13:14:
My Voodoo3 3400 😆
What is a V3 3400 ?
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 12 of 13, by chinny22
Do like a Slot A system, they aren't all that common.
All the parts are more or less period correct, many of us had Netgear NIC's back then.
900Mhz, V3, SBLive. Should be just fine for 9x gaming
Reply 13 of 13, by boggsman
chinny22 wrote on 2024-03-20, 23:41:
Yep! I love having something a little different. I kept most of the parts from back then. It's got enough performance to play any Win9x games very smoothly. I have a blast with this machine.
