First post, by megatron-uk
Currently re-arranging my office, including my audio gear.
At the moment I have 3 modules (MT32, SC55mk2, SC8820) connected to a couple of PC's via a 4-input/1-output MERGE-4 box (www.kenton.co.uk), and the MIDI data stream duplicated to all modules via a 1-input/4-ouput Quadra-Thru (MIDI Solutions).
I really need a minimum of 5 source devices (preferably 6), so the MERGE-4 box is becoming quite a restriction when I want all of the possible computers hooked up at the same time.
Are there any cheap solutions out there that can cope with up to 6 source devices, merging down to 1 MIDI stream? Only *one* of those source devices will be active at any time; so a manual switch would also work.
https://www.target-earth.net
Reply 1 of 7, by Tempus
No, unless it’s passive, you most likely will get issues with the intelligent mode from the MPU-401.
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
Reply 2 of 7, by dionb
"Cheap" is relative. I use a Roland A-880 that I bought in Japan for about EUR 100, but with very cheap shipping. This is an 8x8 patchbay. It was a 110V device but the motherboard uses 5V input, so I disconnected the transformer and modded on an USB power connector. Works like a dream.
Reply 3 of 7, by megatron-uk
dionb wrote on 2024-03-09, 22:55:
Well the Kenton 4-1 merge box was £80 new when I bought it, iirc, so not that different.
I suppose that I could retain the investment in the current merge box by adding another 2-1 or 3-1 merge box to get an extra 1 or 2 ports.
Reply 4 of 7, by darry
Please define "cheap".
That being said, if you have enough outputs snd just need 2 more inputs, why not just stick 2 cheap 2x1 merge boxes in front of your Kenton one (each plugged into one of the Kenton's inputs)?
Reply 5 of 7, by BloodyCactus
kenton make a merge-8. i also have a A880 and its great. not "cheap" are the iConnectivity MioXL (that will be my next upgrade).
Reply 6 of 7, by megatron-uk
Thanks for the tips. I think I agree that one or two 2-1 merge boxes in front of the Kenton Merge-4 is likely going to be the most cost effective route forward.
Reply 7 of 7, by KVM Nerd
Why not go for an Emagic Unitor8 / Unitor8 MkII / AMT8. They are sold under 100 € mostly. They cannot only merge but route 8:8 with SysEx support. Downside is that routing must be controlled via software.
Why not hook it up to a KVM switch?
