First post, by eddman
It seems all games are capped at 20 FPS and I can't figure out why.
The host is capable of reaching much higher values and I remember running the same XP VM many months ago without issue.
Does anyone have a solution?
EDIT:
Turns out the "Background Application Max Frame Rate" option of nvidia interferes with VMware. I had it globally set to 20.
