Das Amt (Need Help!)
First post, by NJack
I want to play the german Game "Das Amt". I mount d with the Syntax:
mount d d:\ -t cdrom
and my harddisk
mount c h:\
When I want to run the game an error appears.
VDFS Error: Dieses Programm braucht MSCDEX oder NWCDEX um auf CD-Rom zugreifen zu können.
(Tranlation: VDFS Error: This program needs MSCDEX or NWCDEX to read CD-Rom.)
Program abortet
VDFSMaker kann nicht gestartet werden
(Translation: VDFSMaker couldn't get startet)
Das Programm ist nun beendet
(Translation: The prgram is abortet now.
Please help me, I want to play this game...
Reply 1 of 7, by HunterZ
What version of DOSBox are you using? You might try a CVS build (see the development forum)
Reply 3 of 7, by Kippesoep
The latest official version is 0.63, but it too is old. CVS builds are many months more recent.
Also, try adding "-ioctl" to the mount command options.
My site: Ramblings on mostly tech stuff.
Reply 4 of 7, by Guest
How should it look like after adding "ioctl"?
Sorry, my englisch is not very well, but im just a stupid german guy 😉
Reply 5 of 7, by TheEvilDoc
hi,
i have the same problem.
i tried this:
mount d d:\ -t cdrom -ioctl -label WTF
but it still doesn´t work
who can help me?
thx
Reply 6 of 7, by DosFreak
heh. the -label "labelname" is the actual label used by the CD that you are mounting. So with the CD in the drive, open up a command prompt in windows, change to the CD drive, type "VOL" and it'll show the label.
Then that's the label that you use in DosBox.
Make your games work offline
Reply 7 of 7, by TheEvilDoc
im sorry it doesn´t work
now dosbox says
error: the file config.dat is incorrect
