First post, by jaskamakkara
Hi everyone. I wish to output a digital signal from my SB0060 sound card (running in a Windows 98 machine, if it matters). I understand that my model of sound card can output an S/PDIF signal through the subwoofer out port, but I am unsure how to hook this up. Do I need some kind of proprietary or special cable? Anyone done this?
Thanks for any help!
EDIT - just to clarify, I am also using the 5" front panel device (Live Drive?) which is connected to the large pin header at the back end of the card. I realise I can just connect a coax/optical cable to this but I would like to be able to output digital audio from the back of the machine, if possible.
Reply 1 of 2, by Joseph_Joestar
You can get SPDIF from that card by simply plugging in 3.5mm to RCA mono adapter into the digital out port (orange jack) and selecting "Digital Output Only" in the drivers. I showcase the process in this post.
Note that this is only for stereo sound. If you want 5.1 surround sound over a digital connection, I think you may need a different adapter.
My retro stuff
Reply 2 of 2, by jaskamakkara
Joseph_Joestar wrote on 2024-03-13, 09:58:
OK, thanks for the info. Stereo is sufficient since I only have a stereo setup. I will get hold of one of those adapters and give it a go.
