First post, by Half-Saint
Half-Saint
Offline
- Oldbie
Are you sure you have FPM memory, and not EDO?
I would also reflash the BIOS chip if you have another programmer or compatible mainboard, just to be sure.
Take BIOS #401A0-0306 from https://theretroweb.com/motherboards/s/asus-pvi-486sp3#bios (not the beta one)
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Good!
And just one tip if at some point you can't get the sound to work, particularly on an ESS Solo-1 chip: BIOS > Chipset Features Setup > Onboard IDE Prefetch Buf > disable.
