First post, by BigMaQ
Hi,
I am trying to get my Windows 3.11 into my Home Network and playing around with some Network Adapters.
I finally got TCP/IP up and running, but always get asked for a Password if I try to access a share (see pic)
What I did on Server Side:
- Enable SMB1
- Enable LANManager / NTLM Auth to Answer in GPO
- Allow empty PW
- Add a local User (with PW)
- Allow „everyone“ and the local User on the share
The server is member of my Homelab Domain, but allow local access to the share without trouble from a more „modern“ PC with XP.
Any nudge in the right direction is welcome 😀
Thx
    216.34 KiB
Reply 2 of 6, by chinny22
Yes, make sure workgroup in Windows 3.11 is set to homelab even if not a member of the domain. This will allow windows to match the homelab\user format the server is expecting.
Create a share on the Windows 3.11 PC and check if the modern PC can access that? I've had it a few times when sharing works one way but not the other.
Reply 3 of 6, by Jo22
Hi, it reminds me a bit of this old thread here: Windows 98 PC suddenly stopped appearing in the Network on my main (Windows 7) PC
Long story short, Windows 9x and WfW used permissions per folder; Windows NT uses permissions per user.
That's why the password thing happens, I think. Also, old Windows used NETBIOS and Lan Manager protocol (aka CIFS, SMB1).
Good luck! 😀 🤞
PS: On modern Windows (NT6+), there's a "homegroup" network type in addition of the old "workgroup" type.
Classic Windows needs the workgroup type. Making sure that workgroup name and domain name are same does help, maybe.
Reply 4 of 6, by Robbbert
On my systems at least, if you install NetBEUI on anything XP and older then there's no trouble mapping drives between them and having 2-way access.
But WFW 3.11 won't access any of my NAS's directly, so I used WS_FTP.
Reply 5 of 6, by Jo22
Speaking of vintage technologies like FTP, there's also serial connection via null-modem cable.
Norton Commander 5.x and FileMaven v3 (DOS) do support it, I think.
Windows 9x and onwards do have Direct Cable Connection utility that's more comfortable than FTP.
It seems to be derived from LapLink technology, which is included in MS-DOS 6.x.
https://www.itprotoday.com/compute-engines/ho … ull-modem-cable
https://en.wikipedia.org/wiki/Laplink
Reply 6 of 6, by BigMaQ
Hi,
thanks for the Input.
Machine is in the same Workgroup (PCQ.LOCAL)
But the FTP Thing I will try out, not as confortable as a direct mapped drive (was hoping to run CD Games from the Share instead of burning these CDs from .ISO)
On Weekend, I will add another, non Domain Server on my ESX (maybe an older Server 2003 or so) and try a bit more. Dont want to „unsecure“ my running file server much more with legacy auth methods 😀 Should also do an isolated VLAN maybe.
