First post, by pete8475
I'm looking to download the free version of Sisoft Sandra 2002 or 2003 but I'm not having any luck.
Are there any mirrors for these old versions?
Apologies if this is the wrong place to ask.
aka pete4237.5
Reply 1 of 2, by asdf53
What I usually do is to use archive.org and go to the manufacturer's website at the time where the version I'm looking for was released. And even if the download links are broken because the file hasn't been archived, it will often reveal the filename of the download which you can then google.
I found this for Sandra 2003: https://web.archive.org/web/20030417032048/ht … x86&langx=en&a=
One of the mirror links still works: https://web.archive.org/web/20030404235612/ht … in32-EN-PHK.exe
And for Sandra 2002, the links are broken but the filename is san859.zip: https://web.archive.org/web/20020323015347/ht … l/dload_x86.htm
There are still many download locations for the file when you google it.
Reply 2 of 2, by pete8475
asdf53 wrote on 2024-03-18, 07:29:
What I usually do is to use archive.org and go to the manufacturer's website at the time where the version I'm looking for was r […]
Thank you so much!
aka pete4237.5
