First post, by willow
I have installed scorched planet 3dfx French/german version on windows 11 using https://www.zeus-software.com/forum/viewtopic.php?t=517 but when I launchegame and arrive in menu. When I click on "Go" button, game crash.
I have tried dgvoodoo 2 or nglide and same thing.
Reply 1 of 6, by legluondunet
Hi!
two years later you finally obtain an answer 😁.
I've encountered a very similar issue with Scorched Planet on modern systems. The game can freeze when clicking the "Go" button, regardless of whether you're using nGlide or dgVoodoo2.
After investigating the original game executable, I discovered a bug in its fade transition routine. On modern systems, a floating-point precision issue can prevent a transition from completing, leaving the game stuck in an endless loop.
I've developed an open-source tool called ScorchedPlanetFix that addresses this issue directly in the game's executable.
It provides:
FadeLow fix: prevents the game from getting stuck during fade transitions.
No-CD fix: fixes the original CD detection issue.
Modern installer: installs the game directly from an original ISO or CUE/BIN image, bypassing the outdated Windows 95 installer.
Support for all three 3dfx editions: US, European EN/ES/IT, and European FR/DE.
The actual FadeLow fix requires changing only 4 bytes in the original executable!
Tested with success on Windows and Linux/Wine.
Latest release available on Github project page: https://github.com/legluondunet/ScorchedPlanetFix
Reply 2 of 6, by willow
legluondunet wrote on 2026-10-31, 01:48:
Hi! […]
Hi!
It provides:
Thanks but It doesn't work with me. Here log file
--------------------------------------------- ScorchedPlanetFix 1.0.0-e945a76d - session start UTC unix_time=1793431970 SYSTEM: […]
SYSTEM: passive Windows / Wine hardware inventory (no personal identifiers)
SYS-INFO: BEGIN (passive startup inventory; diagnostics only; no personal identifiers)
SYS-OS: runtime=Windows native
SYS-OS: Win32 version=10.0 build=26300 (Windows 11-compatible)
SYS-WINE: not detected
SYS-HOST: OS=Windows
SYS-PROTON: not detected (native Windows)
SYS-CPU: model=AMD Ryzen 9 3900X 12-Core Processor
SYS-CPU: physical_cores=12 logical_processors=24 (Win32 view)
SYS-RAM: total=16295 MiB available=7857 MiB (Win32-reported; may differ from Linux host)
SYS-DISPLAYS: active_monitors=1 primary_desktop=2560x1440 virtual_desktop=2560x1440
SYS-DISPLAY: screen=1 device=DISPLAY1 primary=yes resolution=2560x1440 refresh=144Hz adapter=NVIDIA GeForce RTX 2060
SYS-GPU: D3D9 adapter=0 model=NVIDIA GeForce RTX 2060 vendor=0x10DE device=0x1F08
SYS-GRAPHICS-DRIVER: D3D9 adapter=0 reported_module=nvldumdx.dll reported_version=32.0.16.2101 (may be Wine/DXVK wrapper, NOT Linux kernel/Mesa driver)
SYS-DESKTOP: DE=Unavailable (Windows or Wine not exposing XDG_CURRENT_DESKTOP)
SYS-CONTROLLER: totals XInput=0 DirectInput8=0 (an XInput pad may also appear in DirectInput; do not add counts)
SYS-INFO: END elapsed_ms=184 (unknown means unreported, not absent)
CLI: Selected disc image: E:\splanetfix\SPLANET.iso
ISO: parsing read-only image filesystem
ERROR: Unknown 3dfx edition or incompatible files: SPVOODOO.EXE=f709021bf45c3b1d13cc89df1c987bef0260edeab1e804e74507da296ac81362, GEOMETRY.RWB=a2dc1882d66f0d7607a955c8bf9ad28282c3d1d08ca0675a90ca93ecd20f6c69
ERROR (startup): Unknown 3dfx edition or incompatible files: SPVOODOO.EXE=f709021bf45c3b1d13cc89df1c987bef0260edeab1e804e74507da296ac81362, GEOMETRY.RWB=a2dc1882d66f0d7607a955c8bf9ad28282c3d1d08ca0675a90ca93ecd20f6c69
Do you know how solve this problem ?
I have european french and german iso file named splanet.iso
thanks.
Reply 3 of 6, by willow
edit: I have tried avec cue image found on minerva and it works.
I think that your software don't detect my iso.
thanks to solve this problem
Reply 4 of 6, by legluondunet
ScorchedPlanetFix already supports one European FR/DE version, but during my tests I didn't find this one:
I'm curious, it's your personnal CD or you found this version on internet?
If you found this version on internet, could you tell me where by private message, I will add support for this version in ScorchedPlanetFix.
Reply 5 of 6, by legluondunet
willow wrote on 2026-10-31, 07:34:
Thanks but It doesn't work with me. Here log file […]
Hi! […]
Hi!
It provides:
thanks.
Fixed in version 1.1.0 https://github.com/legluondunet/ScorchedPlane … ases/tag/v1.1.0
Reply 6 of 6, by willow
Thanks.
