First post, by kotel
Hi
I recently got this Wester Digital SCSI drive model WDE 4360 as untested. After powering on the drive tries to spin up, but can't. After a while of failed attempts, it makes a loud beep sound, then tries again and stops. I suspect it could be stuck bearing or heads, but I'm not sure. Anyone knows what could be the issue?
"All my efforts were in vain...
Let that be my disappointment."
-Kotel
Reply 1 of 12, by weedeewee
My go to solution for such cases is,
put the drive on a table on its side
lift the drive up a few inches/cm
and
smash it on the side it was standing on, down onto the table
Another option is heating up the drive by having it in a warm/hot place for a while and then trying the drive again.
Do not ask Why !
Reply 2 of 12, by kotel
weedeewee wrote on 2024-03-23, 10:32:
My go to solution for such cases is, put the drive on a table on its side lift the drive up a few inches/cm and smash it on th […]
and
Were you joking with smashing the drive onto the table? I'm not sure about that method. Ill try to heat it up and post the results.
-Kotel
Reply 3 of 12, by weedeewee
kotel wrote on 2024-03-23, 13:36:
and
Nope. It's actually a tried and true method,known to many old time ibm service technicians and likely others.
Do not ask Why !
Reply 4 of 12, by kotel
weedeewee wrote on 2024-03-23, 13:43:
and
After heating the drive up and smashing it on the table, it started spinning, but now it sounds like an engine running when starting, so i suspect a head crash. Anyways ill go plug it onto a scsi controller and see what happens.
-Kotel
Reply 5 of 12, by kotel
Drive is detected in dev manager as COMPAQ ENTERPRISE SCSI Disk Device, but i can't see it in disk managment. HD tune sees it, but it lists as 0MB and crashes as i select it. Any ideas?
-Kotel
Reply 6 of 12, by kotel
Now it has troubles spinning up and seeking. Any ideas?
-Kotel
Reply 8 of 12, by kotel
weedeewee wrote on 2024-03-23, 14:24:
It's dead Jim.
Aww shucks. I was about to write that victoria says drive geometry error when i click passport.
-Kotel
Reply 9 of 12, by weedeewee
You can still use that drive to experiment with whatever you can find that might work on it.
Heck, maybe you can find some unknown trick that gets you a partially working drive again.
What's the worst that can happen? you manage to reprogram the motor drivers, making the discs spin up to such a high speed that they break off and through the casing, decapitating your neighbours prized petunias ?
have fun with it.
Do not ask Why !
Reply 10 of 12, by rasz_pl
my guess: head was stuck to plater, smashnig ripped it off
nothing lost opening the drive up at this point
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 11 of 12, by kotel
rasz_pl wrote on 2024-03-23, 19:52:
But even without functional heads the drive should report the correct size right? Anyways, for people that have a similar issue, a solution might be putting it in a freezer overnight, then hitting it lightly. I managed to fix an seagate drive that had a similar issue.
-Kotel
Reply 12 of 12, by nhattu1986
kotel wrote on 2024-03-27, 14:42:
without the head, when the drive initialize it will unable to read the calibrate data and the drive will report size as 0
