First post, by MSxyz
After having played with a 286 for the past month, it was time to move to something more recent
In this case. it's a ECS Panda 386V motherboard ( https://theretroweb.com/motherboards/s/ecs-panda-386v )
The board in my possession is from 1993 and the BIOS is dated February 1994. The chipset is the ALi 14xx, but the chips are marked "Panda". WTF came up with this name? it would be interesting if somebody knows the story behind this name!. To my knowledge, there are no other chipsets, graphic chips or other ASICs labelled with this brand.
The board is equipped with 256KB of 20ns L2 cache and has two sockets for a 386 and an optional FPU. The board came equipped with an Am386DX-40 but I installed a Cyrix 486DLC-40GP. Oddly enough, the FPU socket contained a Cyrix FasMath in a QFP package, soldered on a socket adapter. (see pic) The reason of this contraption is unknown, especially since Cyrix Fasmath FPUs are available also in a standard 68 pin PGA package.
I installed 8 x 1MB 60ns memory modules. The system appears stable, from some preliminary testing, using the fastest settings in the bios. The 486DLC is recognized by the mainboard and there's even a dedicated settings in the bios to enable/disable the tiny 1KB on-chip cache.
At the moment I'm waiting for a new USB to CF adapter (my old one stopped working) so that I can prepare the hard disk and install directly some DOS games and benchmarks. Meanwhile I'm booting DOS from a floppy and that, at least, allows me to run some benchmarks to confirm that everything is working and that the system is stable.
Here's some preliminary performance data:
Norton System Info 8 : 61.9x (not bad, although I've seen some people claiming 63-64x with a similar setup)
Landmark v60 : 165MHz AT 158MHz FPU
Speedsys: RAM speed 65.6 MB/s - Speed Index 9.71
More to come and pictures too...
Reply 1 of 8, by BitWrangler
There were a few vendors naming boards after ferocious creatures, and Pandas are terrifying, imagine one fell out of a tree onto you, that would be a very bad day.
Reply 2 of 8, by MSxyz
BitWrangler wrote on 2024-03-25, 18:27:
Ah yes, the most ferocious plantigrade in existence 😁
Imagine today some vendors rebranding an NVidia GeForce GPU as a unique, nature inspired, product: meet the nutria GeFrog 4090 Titanium Super AI Hype Edition.
Thanks God for those copyright enforcing laws, eh?
No, seriously... if somebody could write a story about all those fake or rebranded chips that flooded the PC market from the late 80s, I'd be the first to buy his book!
Reply 3 of 8, by Trashbytes
MSxyz wrote on 2024-03-26, 07:17:
Ah yes, the most ferocious plantigrade in existence :D […]
No, seriously... if somebody could write a story about all those fake or rem branded chips that flooded the PC market from the late 80s, I'd be the first to buy his book!
*Cough* DropBear *Cough* would like to know your address to discuss this most ferocious of plantigrades.
Reply 4 of 8, by MSxyz
Today I was able to do some more in depth test.
At the moment I'm using an ISA graphic card, a Geona Systems 7900B (Tseng ET4000AX), one of the best ISA cards of its era.
Results, however, are a bit disappointing in games.
Wolf3d Timedemo : 28,4 fps
Doom Timedemo (screenblocks=10) : 10.07 fps
I believe this motherboard runs the ISA slots at a fixed 7.159 Mhz. Memory transfer speed measured with VSPEED seems to hint at that:
This is VideoSpeed v0.42 by Ilya Tumanov. Copyright(C) 1994,95.
CPU detection routines by Bobby Z. Copyright(C) 1994,95.
CPU type : Cyrix Cx486SLC - 40 MHz
CPU perfomance : 14675 dhrystones per second
VESA BIOS : Not found.
Block size : Normal
Measure results:
Mode Xres Yres Col VFreq HFreq Write16 Write32 Read16 Read32 BlkSize
Hz kHz kb/s kb/s kb/s kb/s byte
004h 320 200 4 69.76 31.04 3379 3379 2177 2177 4096
005h 320 200 4 69.76 31.45 3379 3379 2177 2179 4096
006h 640 200 2 69.77 31.45 3379 3380 2257 2256 4096
00dh 320 200 16 69.76 31.45 3379 3379 2264 2264 4096
00eh 640 200 16 69.76 31.33 3379 3380 2254 2257 4096
00fh 640 350 4 69.76 31.33 3379 3380 2260 2259 4096
010h 640 350 16 69.76 31.45 3379 3380 2259 2260 4096
011h 640 480 2 59.67 31.33 3379 3379 2253 2254 4096
012h 640 480 16 59.66 31.44 3379 3379 2257 2254 4096
013h 320 200 256 69.76 31.32 3379 3379 2615 2615 4096
End of test.
Tomorrow I'll swap the video card with a VLB model. I'm expecting a nice increase in FPS... north of 25% at least!
Reply 5 of 8, by BjornHeimdall
Where can i found this PC-Info program?
Reply 6 of 8, by MSxyz
BjornHeimdall wrote on 2024-03-29, 20:12:
It is from a collection of old (and, sometimes, lesser known) benchmarks and utilities called BENCH_XT
https://brassicgamer.blogspot.com/2022/12/ben … er-systems.html
Landmark 6.0 and CheckIt 3 results. Last benchmarks before I remove the ISA ET4000 and swap it with a VLB ET4000W32
Reply 7 of 8, by MSxyz
Update: I finally managed to install the VLB card
The operation was not without hassle. Upon powering up the PC for the first time, I was welcomed by a black screen and a cacophony of beeps. Disappointing, but -at least- the PC showed signs of life. Old cards and motherboards tend to have oxidised contacts or dust in the connectors, so I found that scrubbing the contacts with a solvent/cleaner and inserting and extracting the cards repeatedly from the slot usually does the trick. Anyone who had the 'pleasure' to work with VLB cards knows how difficult is to remove one from the slot; it takes patience and a good dose of strength, but not too much, else...
After around 10 minutes of fooling around with the card, I finally managed to have a picture on screen: the PC could complete the mem test but it would hang soon after the "press <DEL> to enter setup" prompt. I managed to enter the BIOS (by sheer luck after the nth attempt) and loaded the 'failsafe defaults'. Boom! The PC now booted MS DOS and seemed to run stable.
Now it was time for some guess work. I changed, one by one, all the settings in the BIOS back to the optimal state and rebooted after each change. It turned out it was the last (!!!) option in the advanced setup which caused the system to hang. The option reads "Delay ISA Cycle LDEVJ WS" and the system will hang unless I choose "3 CLK2" as option. The rest of the BIOS was configured back to the fastest setting that I could find by trial and error. On a side note, on the motherboard, there is a jumper that should be closed when the VLB bus works at a frequency above 33MHz (most likely it relaxes the timings a bit) but the card is rock solid also by leaving this jumper in the 33 MHz position.
The card I've used is a California Graphics Suntracer 2000v based on the Tseng Labs ET4000W32 with 2MB of 45ns DRAM. There is little information regarding this specific card or California Graphics in general, although I do remember that it was a fairly well known brand in enthusiast circles. All I've managed to find was an old ad in an Italian Magazine of the era.
Anyway, if you're reading this, you must be interested in the numbers... here are some:
Wolf3d time demo went from 28,4 fps to 48,4 fps. That's a 70% increase!!!
Doom timedemo (using screenblocks=1o, that means full screen, but with the status bar at the bottom) went from 10,0fps to 12,8fps. That's a decent 28% increase, more in line with the expectations.
I also ran the Quake timedemo at 320x200, but -predictably- frame rate went up only from 2,3fps to 2,4fps..
Last, I ran VSPEED to check the transfer speed over the local bus. I was really impressed by the result:
004h 320 200 4 70.30 31.57 18509 32576 5894 9525 4096
005h 320 200 4 70.31 31.57 18474 32468 5841 9812 4096
006h 640 200 2 70.30 31.69 16649 20838 5824 5769 4096
00dh 320 200 16 70.30 31.57 16649 20882 5810 5632 4096
00eh 640 200 16 70.31 31.69 16620 20838 5852 5786 4096
00fh 640 350 4 70.30 31.57 16649 20882 5855 5941 4096
010h 640 350 16 70.31 31.57 16620 20838 5855 5806 4096
011h 640 480 2 60.13 31.57 16649 20749 5852 5735 4096
012h 640 480 16 60.13 31.70 16649 20838 5852 5748 4096
013h 320 200 256 70.31 31.69 18830 37733 7025 13498 4096
Write speed in VGA mode 13h (330x200) is now 37733 KB/sec versus 3379 KB/sec of the old ISA card. That's more than a 10X increase!
Reply 8 of 8, by MSxyz
Today, I repeated all benchmarks and saved a lot of screenshots that will go into my folder of fun vintage projects.
I never owned nor used a 386 with Vesa Local Bus before, but now I'm convinced that even this 'old' processor can benefit from a faster bus to the graphic card. That +70% in Wolf3D is surprising, and even +28% in a demanding game like Doom is nothing to scoff at.
As for the Cyrix 486DLC, it's a nice processor although it possibly came a little to late to steal the limelight from Intel. It's not "just another 386/486 clone". It's an original in-house design that shares some common traits with the 486 (which, in itself, it's nothing out of the ordinary... its 5 stage pipeline design originated from Berkeley and was adopted by many different vendors to many different architectures). Even with its cache turned off, the Cyrix 486DLC is faster -clock for clock- than a 386. The tiny 1KB cache gives it an additional 20..30% boost in most benchmarks and applications, which -again- is nothing to scoff at.
File is closed. Now onward to my next retro project: assembling a functional PC with a Cyrix486S (the so called FasCache), possibly using a motherboard that can take advantage of its unique features.
