Reply 40 of 47, by myne
What does mem show now?
You had a bunch of stuff in there before.
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 41 of 47, by Demolition-Man
Tried it unter Win98:
Best i can get is: "The planet Arakis..." then silence. Only music. 586KB free Memory.
Thats why i am using real DOS and Win98 SE.
Reply 42 of 47, by eddman
I just tested the US CD release in 86box in a guest machine with 128 MB RAM and a Sound Blaster 16 non-PnP. In the game's setup I chose SB Pro and also enabled XMS, which says 596 KB free mem is required.
36.76 KiB
Here is a video recording I made, with config.sys, autoexe.bat and mem/c/p:
https://drive.google.com/file/d/1twVEEYuTTszL … W0dSUP3Z1e/view
Reply 43 of 47, by Demolition-Man
Yeah you have enough free memory, just like me, but only in pure DOS.
Dune II need close to 600 kb free RAM. And 1 MB (?) of additonal XMS to work properly. (speach)
Edit: 596 kb^^
Reply 44 of 47, by eddman
Demolition-Man wrote on 2024-03-30, 18:46:
That's not in DOS.
EDIT: Wait, you meant YOU get enough mem in DOS. Yea, but you can get it to work in Windows too.
Reply 45 of 47, by Demolition-Man
I`m not sure, looks like 586 kb free RAM ist the best i can get.
I don't know why I'm even interested in troubleshooting DOS games in Windows 98. Windows 98 is not the solution, but the problem. 😉
Reply 46 of 47, by myne
Dune works now.
They're on another problem
Things I built:
Reply 47 of 47, by OpenRift
Okay so I think I found a solution that allows me to run both Dune II and Monster Bash without issue.
By putting "Device=C:\Windows\EMM386.EXE 150 RAM" in the CONFIG.SYS and adding "EMMPageFrame=C800" under the "[386enh]" section of C:\Windows\SYSTEM.INI, both games work under the same configuration (shoutout to this reddit post for the idea).
So far, no other games seem to be having any memory-related issues, so I think we may be in the clear, but we'll see. If I run into any other problems, I'll post an update.
EDIT: changing the parameter to "1024 RAM" also works too!
