First post, by Dothan Burger
- Member
I have a little ITX 98/XP gaming box I like to bring to LAN parties because it's convenient. The Intel 945 chipset works well with 1000Hz polling once Windows is running but starting the machine with the mouse plugged in causes Windows 98 to load to a black screen and freeze.
Does anyone have any luck booting with higher polling rates? Both 500 and 1000hz polling cause the same issue.
