First post, by LequaRex
Hi! I'm new here!
Let me just get right into my problem. So far I have used four versions of SeaTools.
I burn the iso to CD / write it to a floppy with the supplied installer.
I reboot my PC and select the CD drive/FDD to boot from first. SeaTools loaded it's graphical interface, but it won't detect my 2,5" Momentus 7200.3 80GB SATA drive, which is directly connected to my MSI MPG B550 Gaming Plus. The drive is a ST980411AS. The drive is not dead. I can definitely write to it in Windows 10. The BIOS and SeaTools for Windows shows the drive, but says, it's not supported to adjust capacity.
I also tried it on my retro PC (a Compaq Deskpro 2000 5233MMX with currently no hard drive, so therefore no BIOS), but it won't even load the GUI. It stays at the "(SeaTools boot) C:" screen and I should reboot.
    1.86 MiB
    After it booted and I accepted the agreement
Reply 1 of 4, by darry
Hi,
You could try
EDIT: You will likely need to make sure that the disk controller is not set to AHCI or RAID for at least some DOS based tools to work. RAID mode will also be problematic under Linux, though AHCI should be fine
https://hddguru.com/software/2006.01.20-Hitac … e-Feature-Tool/
or
Hdat2
or
maybe hdparm under Linux (like in this example)
Re: Here's an idea: using high endurance (micro)SD cards meant for continuous video recording as storage for retro gear
Reply 3 of 4, by darry
What do you want to change on drive ? Lower its reported capacity ?
In that case, you might try the Linux approach in the modern PC or the Hitachi Feature on your old one.
Be careful, though, as hdparm, AFAIK, can actually kill a drive or at least make it hard or impractical to recover if misused .
Reply 4 of 4, by LequaRex
UPDATE: It couldn't detect the Seagate drive. Only my DVD drive
Yes, change the capacity, but is it really possible to use the Hitachi Feature on my old one? I mean it doesn't have a BIOS installed and therefore an 8 GB Limit, but I have an 80 GB drive.
