First post, by Skalabala
Hello everyone, hope you are doing well 😀
Saw this and found it interesting, no cache chips and no TAG chip. Note the date code of the north bridge
I did a google search and I found a same one but the date code was 0307!
Ebay link, hope its allowed 😁
https://www.ebay.com/itm/326020694005?epid=74 … ABk9SR_zK-sbTYw
Reply 1 of 17, by Nexxen
Skalabala wrote on 2024-04-02, 01:54:
Not bad 😀
I did a quick search and my conclusion is that L2 + TAG were desoldered.
Pics have either 1 or 2 L2 chips installed (512 or 1MB).
Odd but not uncommon solution if it was used for spares at some point.
Unless I'm utterly wrong 😀
No L2 should make it hang possibly. Strange
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 2 of 17, by Trashbytes
Nexxen wrote on 2024-04-02, 02:33:
Not bad :) I did a quick search and my conclusion is that L2 + TAG were desoldered. Pics have either 1 or 2 L2 chips installed ( […]
Not bad 😀
Spares board would be my initial guess too, I cant really think of many other reasons for removing both Cache and Tag ...Im guessing it may run just fine with L2 disabled in BIOS and using a K6-2+ or K6-3 / + since they have their own L2 and dont need L3 to work.
Reply 3 of 17, by Repo Man11
I wonder if this was just a quality control issue? If those chips were removed, someone did a very neat job of it.
Reply 4 of 17, by Trashbytes
Repo Man11 wrote on 2024-04-02, 02:39:
Yeah, very clean job .. too clean one might say.
Looking at other 1.2a boards they all have two Cache chips .. so an exceptional job in removing both that clean.
Reply 5 of 17, by kingcake
I think the obvious answer is this was a board revision for a low cost system integrator that wanted to save a few bucks on cache chips.
Reply 6 of 17, by Trashbytes
kingcake wrote on 2024-04-02, 03:11:
Maybe but the FIC VA 503+ was a high end board back in the day, not a board I would have ever chosen for a low cost system, even with no Cache the board would have still been more expensive than other low cost budget boards already on the market at the time.
Not saying you are wrong here just adding a counter point.
Reply 7 of 17, by Nexxen
Trashbytes wrote on 2024-04-02, 02:41:
I did the same in the past days and you couldn't tell something was soldered there.
Pic in bay is blurry, not a sharp HD.
This is a TRW job to sort 😀
Well, only buyer will tell what's the answer 🤣
Retro mystery!
Reply 8 of 17, by Trashbytes
Nexxen wrote on 2024-04-02, 03:18:
I did the same in the past days and you couldn't tell something was soldered there. Pic in bay is blurry, not a sharp HD. This i […]
Retro mystery!
I have a DFI K6XV3+ /66 that needs another Cache chip ...they are very similar in design to these ones .. how hard are they to add to a board ? Just curious about difficulty before I jump in.
Reply 9 of 17, by Nexxen
Trashbytes wrote on 2024-04-02, 03:22:
Retro mystery!
Depends on how much room you have to solder. I used solder paste and a soldering iron, not hot air. 217°C and 183°C temps.
It's way faster than solder dragging and way faster for touch ups. My 2 cents.
Othrewise flux and soldering iron is good but requires more patience.
Not difficult, just slow, steady and patience.
Patience is the key and... I sound like I'm selling door to door 😀
🤣 got the tip?
Reply 10 of 17, by Horun
Hmm Interesting ! The back stickers are not same as my two retail boards. The one green inspection tag has only 3 squares, mine have 5 like pic at trw and other ebay pics.
Reply 11 of 17, by kingcake
Nexxen wrote on 2024-04-02, 03:29:
Depends on how much room you have to solder. I used solder paste and a soldering iron, not hot air. 217°C and 183°C temps. It's […]
Retro mystery!
🤣 got the tip?
Soldering iron with solder paste? What's your method? When I do high density chips I either drag, or use paste + hot air and board heater
Reply 12 of 17, by Horun
🤣 same seller has a msi 6905 slocket for $229. wtf I seen enough..tards 😁
Reply 13 of 17, by majestyk
I have seen a cacheless PA-503+ on Ebay before (with better pics).
I think it was, like kingcake said, a cheapo version.
You can add the chips indeed, but 1MB cache is the maximum here (due to 28-pin TAG limitation):
2 chips (or 1 chip) 64K x 64 (4nS) and a 32K x 8 TAG chip (8nS). There are probably also a couple of resistors around the TAG chip missing.
Reply 14 of 17, by Anonymous Coward
Trashbytes wrote on 2024-04-02, 03:17:
That's a bit of a stretch. Super Socket7 boards were mid-range at best.
I bought the VA 503+ when it came out, and I paid 89 bucks for it.
Reply 15 of 17, by Nexxen
kingcake wrote on 2024-04-02, 04:04:
It's just what's faster and easier to do the job, for me.
Also being L2 cache I don't find easily, I avoid hot air if possible.
Solder paste makes touch ups really easy on such small leads.
Reply 17 of 17, by majestyk
The late ALi chipset revisions made the northbridge´s on-chip TAG-RAM usable, but you would still need the cache chip(s).
