First post, by eddman
The game wasn't even launching on Windows 10. Windows 98 compat mode does make it work but prevents dgvoodoo from working. After some trial-and-error it became apparent that the game only needs the "Win98VersionLie" compat fix to launch, so I applied only that with Compatibility Administrator and dgvoodoo also works with it.
The problem is that the game doesn't allow to select DirectX or OpenGL in the settings, with or without dgvoodoo. I tried all the video card types in dgvoodoo but no change.
This is also the case when using Windows 98 compat.
The attachment csi1.jpg is no longer available
This isn't directly dgvoodoo related of course. Obviously OpenGL is not supported, however, is it something that can be done on the wrapper side for DirectX?
If not, does anyone know how can I trick the game to allow using those options?
I've also attached a log file.
Reply 1 of 8, by Shagittarius
eddman wrote on 2024-04-07, 15:40:
The game wasn't even launching on Windows 10. Windows 98 compat mode does make it work but prevents dgvoodoo from working. After […]
The problem is that the game doesn't allow to select DirectX or OpenGL in the settings, with or without dgvoodoo. I tried all the the video card types in dgvoodoo but no change.
https://www.pcgamingwiki.com/wiki/CSI:_Crime_ … nd_DirectX_mode
The game won't let me select OpenGL and DirectX mode
It occurs because the game does not correctly recognize modern video cards but it is still not a problem since it lets you select the software renderer and there if it works correctly
Can't name a profile
Don't enable compatibility mode
Reply 2 of 8, by eddman
Shagittarius wrote on 2024-04-07, 15:47:
https://www.pcgamingwiki.com/wiki/CSI:_Crime_ … nd_DirectX_mode […]
What's the point of copy pasting that?? Why do you think I'm asking here how that can be fixed.
If you read what I wrote above you'd see I'm NOT using the Windows compatibility mode. I can name a profile with no issues.
Reply 3 of 8, by Shagittarius
eddman wrote on 2024-04-07, 15:52:
Wow
Reply 5 of 8, by Shagittarius
The reason for the message is there is no difference in the other modes, unless you need D3D assisted video acceleration to make the videos run the proper speed it will look no different. This game is not 3D its just videos.
Additionally I've been trying to test the game out on my XP machine but it has an issue with Version 6 of Quicktime, and Version 7 no longer supports FLash video. But I have a 780ti in that machine and I can choose all the different options even though I see a white square instead of a video.
Reply 6 of 8, by eddman
I'm testing things, seeing what difference each mode makes, which dll files are loaded, and what purpose they have for a video based game. The goal is not to just play the game.
Reply 7 of 8, by BEEN_Nath_58
Apparently the Direct3D and OpenGL modes are properly detected on Intel integrated cards...
Reply 8 of 8, by Dege
I don't know what OpenGL and DirectX means in this game because the game itself does not even touch DDraw. I get the same result with integrated Intel too.
It's only the QuickTime player that plays the videos through DDraw.
Anyway, I added YUY2 and UYVY format support into DDraw (the video player tries to use those formats).
