First post, by legodude
Hi All,
I accidentally ended up with a NCR 486 recently, and I can't find anything about it with my googling. This looks like a very primitive system to me. It is a 486DX 50mhz with 8mb ram. There are four 16bit ISA slots on a riser. The badging is NCR 3300 Model 5100. There is one for sale on Ebay right now:
https://www.ebay.com/itm/196011692915
I lifted their motherboard photo:
397.29 KiB
Here are photos of my system:
685.22 KiB
1.12 MiB
1.67 MiB
1.21 MiB
Can anyone provide further information about this system or possibly a bios update? I can't find it on the The Retro Web - there are similar-ish systems, but no perfect match. I can't seem to put in custom hard drive geometry, it seems to ask for a "USERHDD" utility, which I also cannot find. There are a few references to userhdd.exe on a German forum from 10-20yrs ago, but that's it
thanks
mike
Reply 1 of 6, by Horun
Found it in the NCR archives. The original name was 3330UHDD.EXE, a self extracting file with userhdd.exe and .txt inside.
Attached as a zip. Here is the source: https://web.archive.org/web/20001212095600/ht … rary/3330.shtml
I suggest you grab all the other files too...
    3330UHDD.zip
    18.67 KiB
    6 downloads
Reply 2 of 6, by esasoft
Found all that too.
The most recent page in WA:
https://web.archive.org/web/20041212163524/ht … pc_library_3330
Maybe something useful here:
https://web.archive.org/web/20040203152631/ht … ers_patches.asp
https://www.ardent-tool.com/NCR/
Reply 3 of 6, by Horun
Great ! Did find some notes about an addendum to manual but no manual....
Reply 4 of 6, by legodude
Thanks so much. I'm embarrassed that I did not even think to check archive.org. My bios is E.5, which looks to be the second newest version - judging by the date strings in the bin file, E.5 is a few months older than E.6. The note that "The 3330 does not support flashable BIOS upgrades so you will need access to an EPROM burner"is a bit of a buzzkill. I'm happy to buy an EEPROM burner if needed, but I'm not sure this NCR is going to be enough of a reason.
The "service diag disk" is shockingly useless. Other than finding that I have 1mb of video ram, I didn't find anything of value.
USERHDD did not work on my first pass through, but I'll fight with it some more before giving up. This whole system is giving me "proprietary in a bad way" vibes.
mike
Reply 5 of 6, by Horun
Yeah being 1993 bios without Large or LBA modes it will have a 504/528Mb size limit of 1024 cylinders, 16 heads and 63 sectors . So if you want to use a 1GB HD then Ez-Drive/Drive Pro/etc would be your easiest way...
Reply 6 of 6, by legodude
Just to follow up on this... the USERHDD program is odd:
-Enter drive geometry into USERHDD and save, reboot
-Enter setup, change drive type to 1, save, reboot
-Enter setup. Only after two reboots will drive geometry show up in the bios.
I have not tested extensively, but I believe the 1024/16/63 limit is accurate. USERHDD explicitly lists the cylinder limit, but not heads or sectors.
mike
