First post, by Figgy2112
Hi, I have a vintage pentium 3 computer with 384mb of ram I’ve been using and successfully running DOS 6.22 and windows 3.11 but some apps and stuff on windows 3.11 Run Way too fast, It’s even so fast that the windows 3.11 start up screen doesn’t even show but just directly goes in, Is there anyway I can limit it down so it doesn’t go so damn fast and I can see the boot up screen?
Reply 1 of 12, by rmay635703
If you use a vintage version of himem.sys you will get either 64mb or 16mb as that is all it supports.
Your issue is actual cpu speed, disabling L1 & l2 should slow you down enough or there is this
Throttle Blaster
Reply 2 of 12, by Jo22
Hi! To be honest, I have barely seen the Windows 3.1 splash screen since the Pentium days anymore (586, ~75 Mhz).
I think it's a general problem on newer computers with the splash screen no-longer being visible.
I remember watching it, though, when I had my 12 MHz 286 PC, still.
To make the PC slower and make these Windows 3.1 games run at playable speeds again, there are several workarounds.
a) disable L1 and/or L2 caches in CMOS Setup Utility ("BIOS")
b) use a slow-down utility, such as Mo'Slo
A few utilities are being mentioned in this 21,5 years young thread over here: List of Slowdown Utilities (Beta)
That being said, I haven't really tried that so far. I've used emulators (PCem, DOSBox) to run timing-sensitive games (Lander 3..).
Or vintage hardware, simply. A 286 to 486 laptop with 4 MB RAM is fine for running Windows 3.1 natively.
The lack of a sound card on a vintage laptop might be an issue, though.
The speaker.drv driver works for sound effects, but not FM (a few games used MIDI and FM).
Good luck! 😀 👍
Reply 3 of 12, by Figgy2112
Well, the bios is from a dell dimension 4100 And it doesn’t seem to show that option for that cache, But here’s a screenshot of mem when I’m in DOS
    1.24 MiB
Reply 5 of 12, by Figgy2112
Jo22 wrote on 2024-04-10, 02:14:
Hi! To be honest, I have barely seen the Windows 3.1 splash screen since the Pentium days anymore (586, ~75 Mhz). I think it's […]
Good luck! 😀 👍
I think the reason It doesn’t show it boot is because it goes by so quickly as the resolution changes over on the monitor, I wonder if there’s a way you can configure it to delay it loading or have it go longer so you could see it
Reply 7 of 12, by Jo22
Figgy2112 wrote on 2024-04-10, 02:44:
I tried already using himemx with the limit, but windows refuses to boot without himem.sys in the config
Windows 3.0 doesn't need himem.sys (win /r). :)
Reply 8 of 12, by Figgy2112
Good luck! 😀 👍
I used The tool called slow down in the thread and actually had success!!, I’m able to use what I was trying to use at the correct speed and nothing goes too fast and doesn’t crash
    1.71 MiB
Reply 9 of 12, by Jo22
Cool! I'm glad it works now! 😁
Reply 10 of 12, by Shponglefan
Figgy2112 wrote on 2024-04-10, 01:02:
That's a bit odd that it's not showing the splash screen. I've been running a Pentium 4 3.4 GHz w/ 2 GB of RAM with Windows for Workgroups 3.11. It always shows the splash screen before loading.
The only OS I have installed that doesn't show a splash screen is Windows Me.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 11 of 12, by Jo22
Shponglefan wrote on 2024-04-10, 23:13:
Hi, is networking enabled by any chance?
If so, getting the network address via DHCP might keep Windows busy just long enough to display the splash screen.
Another cause might be the SB16 MIDI driver looking for a non-existent (disabled) MPU-401.
I had this problem once in Virtual PC 2004/2007 (has incomplete SB16 emulation).
Reply 12 of 12, by Shponglefan
Jo22 wrote on 2024-04-11, 11:43:
Hi, is networking enabled by any chance? If so, getting the network address via DHCP might keep Windows busy just long enough t […]
No networking, no SB16 driver.
Splash screen appears for about a half second before disappearing, but it is visible.
