First post, by psaez
Hi
I installed Windows 98SE on a SD using a sd to ide converter. It works, but when I'm copying data, for example various hundreds of MB from one folder to other, sometimes OS get frozen for some seconds. Also happens when I install software.
How can this be solved?
Thanks
Reply 1 of 1, by Shagittarius
Make sure DMA is enabled for your drives.
The attachment DMA.png is no longer available
