First post, by megatron-uk
In my recently completed 486 single board computer, I have been checking all of the games I want to run on it.
Over 95% run great, but there are a few which have problems. This is Sim City Classic, the updated version with the Maxis config utility, mt32/GM music options etc.
If selecting either 640x350 EGA or 640x480 VGA then the main game interface is all corrupted. It looks to me as though a VGA bios font is being used and is corrupt.
283.67 KiB
This is using a C&T 65550 VLB chipset.
Has anyone seen a similar problem on any other VGA cards or bios images?
Of 213 other games, only one other shows similar symptoms, and that is Shadow of the Comet, specifically the installation utility which looks the same.
https://www.target-earth.net
Reply 1 of 4, by Tiido
As far as I know, it is due to the VGA BIOS lacking 8x14 font in it, which a lot of later chipsets started to omit to make room for things like VESA stuff. I think there is a TSR somewhere that helps to fix this issue but I don't remember any details unfortunately.
Reply 2 of 4, by keropi
I think this will work perfect: https://www.bttr-software.de/products/fix8x14/#down
Reply 3 of 4, by megatron-uk
Excellent work guys.
The diagnostic utility confirmed that the 8x14 font was indeed missing:
170.51 KiB
With the TSR loaded before starting SimCity it resolves the display issue:
240.15 KiB
I'll need to go back and check the other games that are installed, but I am pretty sure the only other instance I had was with the installer / setup for Shadow of the Comet.
Reply 4 of 4, by megatron-uk
Yep, the Shadow of the Comet installer has the same issue with 8x14 fonts:
212.74 KiB
This was one of the few games that I couldn't get running on the 486SBC system... No wonder when I had zero chance of reading the items in the configuration menu!
The tsr fixed this one, too:
149.81 KiB
