Am I missing something?
First post, by pavelk
Did I forget how to run a program?
Thanks,
Pavel
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
Funky 😀
See if the file is readonly/hidden or something. Do other .exes work?
Reply 2 of 7, by pavelk
Other .exe's do work interestingly enough. I don't assume this is a fault with the .exe, however, I could be wrong.
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
No this is before the .exe is loaded. Did you have a look at the attributes
or file permissions of that .exe file?
Reply 4 of 7, by pavelk
Coming from UNIX I'm not entirely sure how DOS checks/modifies file permmisions/attributes from a file.
Is there a chmod, ls -l, or stat equivalent for DOS?
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
Not inside dosbox, in your host system.
What you could additionally try: in dosbox copy the files into a
different directory, something like
md test
copy *.* test\
and then try running the executable.
Reply 6 of 7, by pavelk
wireless-199-246:~/games/1paga Pavel$ stat -l INSTALL.EXE
---x-wsrwt 1 Pavel Pavel 142122 Dec 1 13:02:00 1991 INSTALL.EXE
I did a
 chmod 777 *
on the install.exe in the 1paga file, and it seems to work now. My memory is somewhat fuzzy, so I don't particularly know whether or not permissions get preserved through zip files, but according to the stat, I still had permission to run the file....
Thanks,
Pavel
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox needs read acces (as it open the executable so it can run the code inside)
Water flows down the stream
