First post, by manic232
- Newbie
I have a brand new SNES that is for Singapore/Malasia/Indonesia markets only (says on the box) Will this work in the UK without issues? It says it is PAL so i guess it will?
Just check the primary voltage on the AC adaptor, make sure it's 240V for UK outlets.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
wrote:I have a brand new SNES that is for Singapore/Malasia/Indonesia markets only (says on the box) Will this work in the UK without issues? It says it is PAL so i guess it will?
Yes it will work fine 😀. The standard voltage in Singapore, Malaysia and Indonesia is the same as the UK (220-240V @ 50hz), so the power pack should work fine if you use an adapter or wire on a 3-pin plug 😉.
Many thanks for that, actually the plug looks like a UK plug, so I might not even need to do that, I will try it and post back if it works
My System: SuperMicro P6SBA Motherboard, Win98SE, PIII 600Mhz, 256MB Ram, Voodoo 5 5500, SB AWE 64 Gold Sound Card, Roland LAPC-I
Didn't check this thread in a while.
Yes, Malaysia uses the same as UK. Even the 3-rectangle-pins power plugs are the same as the UK, and voltage runs at 50Hz. The same is true for Singapore and Indonesia. I think in Indonesia, more appliances use the 2-rounded-pin plugs.
Thanks again for your help, It worked perfectly, I was very happy with it actual it was New Old Stock, Mint..... nice
