A weird problem
First post, by DragonsLover
HELP ME!
I have a weird problem with VDMSound on any games I try. Each time I select "Run with VDMSound", I get this error message:
16-bits MS-DOS Subsystem
C:\Documents and Settings\[My name]\Local Settings\Temp\~VLP****.PIF
C:\Documents and Settings\[My name]\Local Settings\Temp\~VLP****.NT
The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the application.
[Close] [Ignore]
Clicking on "Ignore" does the same thing as "Close".
What can I do? I can't get sound in any games! Please help! 😢
I'm using Windows XP Home SP2
Reply 2 of 16, by franpa
C:\WINDOWS\repair
copy the files from there into your C:\WINDOWS\SYSTEM32
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 3 of 16, by DragonsLover
Should I copy all the files in the Repair folder or only Config.nt and Autoexec.nt? Because if it's only these two ones, it still doesn't work. I have even taken "ntvdm.ex_" from the CD (renamed to "ntvdm.exe") and put it in the System32 folder and it still doesn't work. Should I take "ntvdm.dl_" too? 😢
I like dragons! They're the center of my life! I'll never forget them...
Reply 5 of 16, by DragonsLover
I did expand all the mentioned files from the original CD to the System32 folder: Still doesn't work.
Even taken the files from Repair folder: Still doesn't work.
Reply 7 of 16, by DragonsLover
I'm using VDMSound 2.1.0.
As for Dosbox, the problem is that I wanna play the first Tomb Raider using "Tomb Raider Advanced Installer" that improves the graphics with dgvoodoo. I can't use Dosbox in my case.
Help!
Reply 8 of 16, by DosFreak
Read this thread: 16-bit subsystem error "Your system is not suitable for running 16-bit apps"
Also how does Dgvoodoo improve the graphics? AFAIK, "all" it does is allow the glide version of TR to work. Is there such a big difference between the VESA and Glide versions of TR?
The only major difference AFAIK is that the Glide version's textures can be replaced if your using GliDOS.
Make your games work offline
Reply 9 of 16, by donehogawa
I had a similar problem and, yes it may sound stupid, I solved it just
updating my video drivers .
Reply 10 of 16, by vladr
Does you username contain funny characters (non-ASCII?) I refer to C:\Documents and Settings\[username]\...
If so, it might be the explanation.
Reply 11 of 16, by Lord_VEK
I wonder, how can non-ASCII characters influence the matter?
I've got the same problem, the same error messages(and the same VDMSound version). And the config/autoexec files were NOT corrupted, nothing that there shouldn't be. Then I followed MS's advice after reading http://support.microsoft.com/?kbid=324767
No result still =(
OS- XP Pro. Game wanted to run - M.A.X. Actually it works under DOSbox BUT! No sound! The setup autodetects SoundBlaster or GUS emulated by DOSbox, but the game itself has no sound!
Reply 12 of 16, by vladr
Do you or don't you have non-ASCII characters in there?
Reply 13 of 16, by Lord_VEK
Russian characters => not of the first 128 ones.
Reply 14 of 16, by vladr
so it won't work - limitation in windows' pif IIRC
one possible workaround is to set the TEMP user environment variable to a directory where you have access but whose path is made out of ASCII characters (e.g. c:\windows\temp if you are admin)
V.
Reply 15 of 16, by Lord_VEK
Thanks 😉
Reply 16 of 16, by Lord_VEK
(though only the problem of running VDMSound is solved, no the one with having sound =( But that's another topic
