Nicht Sehr Gut wrote:
Sorry.
Nicht Sehr Gut wrote:Look under "Download" for the Launchpad. Vlad refers to it as a Beta, but it's rock-stable. […]
While you are at it, go ahead and get the Update files first from
http://vdmsound.sourceforge.net/files/
(Has "update" in the filename). No install script, just copy it on top of your older VDMSound files.
Did these. I really have no idea what this stuff does, but if it helps, sure.
Whenever you run a DOS executable with VDMSound it creates a .VLP shortcut in the same directory. That is what I was referring to, the VLP shortcut.
Ah, now it doesn't give me the no CD message. The bad news is, other errors pop up. Here are what they say:
VDMS Launchpad - C2CD (Filename)
The NTVDM CPU has encountered an illegal instruction.
CS:df2c IP: 0000 OP: ff ff ff ff 40
Choose 'Close' to terminate the application.
When I click 'Ignore'...
CS:df2c IP: 0001 OP: ff ff ff ff 40 c8
Clicked 'Ignore' again...
CS:df2c IP: 0002 OP: ff ff 40 c8 00
And again...
CS:df2c IP: 0268 OP: 63 0e c7 00 00
Again...
CS:0000 IP:c79a OP: fe 1f 00 00
And a few more.
Any ideas?
EDIT - When I clicked the "Enable basic Vesa support" where the No-CD thing was fixed, and then tried, a window got maximized where it looked like the game was going to work. Does that make sense? Unfortunately, the error messages popped up a moment later.
