First post, by Dracas
I notice someone else posted on here that they got Impulse Tracker (2.14?) to work correctly with VDM Sound and thought someone might have some advice because when I try using windows NTVDM I have plenty of memory to work with in Impulse Tracker, but when I use VDMSound to emulate the soundblaster environment, theres barely enough memory to load maybe one or two samples. I've cranked the memory up as much as I can in the IT programs memory tab (Conventional memory can't be changed apparently, it automatically goes back to 'auto')
Here's what IT reports when it loads up
Freemem: 51k
FreeEMS: 0k
That 'FreeEMS' note should have a big old 16083-ish next to it but for some reason WinXP or VDMsound or *something* is ignoring the memory settings.
Here's what the Memory tab looks like in Impulse Trackers Preferences PIF:
+ Conventional Memory
- Total (Auto) *Protected on
- Initial Environment (4096)
+ Expanded (EMS) Memory
- Total (16384)
+ Extended (XMS) Memory
- Total (16384) *Use HMA off (turning it on doesn't help)
+ MSDOS Protected-Mode (DPMI) Memory
- Total (16384)
There you have it...not having any luck clearing up the memory issues, almost seems like the EMS memory isn't loading at all, or WinXP is ignoring it. But since I didn't know where else on the net I could go for help using VDMSound (since IT and VDMSound are almost universally linked at this point since its the only way to use it on WinXP/2K) I'd appreciate some help
Thanks a bunch
~Drac
