Originally posted by Unregistered ...but the Amiga version had slightly better music.
SLIGHTLY?
*throws spoon at Unregistered*
I think he means "glaringly obviously better"
A lot less trouble than tweaking the DOS version.
Well, there are few things you need to tweak on the Amiga side as well. To be fair, that's because it was as flexible as the PC in configuration.
One thing to remember, unless he's already familiar with the Amiga and the way it works, it may actually be more frustrating (the "unlearning" problem). Having said that, I'm always been a big Amiga Advocate.
Best settings to adjust (for me) for WinUAE with ChaosEngine:
Kickstart 1.3
Resolution: 640x400 (full-screen), Horizontal & Vertical Centering
Line Mode: Doubled
ChipSet type: Full ECS, NTSC
Floppies: Two Drives (for both disks), speed setting to 800% (Turbo locked on me)
IIRC, there was no hard-drive installable version for the Amiga, but I'm sure someone has come up with a hack for that. Of course, that means more "fiddling" with the setup.
