First post, by Unregistered
I have Monkey Madness and Windows XP. I downloaded LEC Quick and Easy and I am trying to get the games to work with VDMSound, yet they don't. I go to the setup and I locate where the resource files are. I click 'Start', but nothing happens at all. Is there somethine I am missing?
Thanks for your help.
Reply 2 of 4, by bgbennyboy
If you are using Q+E then remember there are 2 targets, for normal mi1cd and for the floppy versions/monkey madness. If nothing happens then you've probably given it the wrong path.
But yes, ScummVM is a better option, get ScummVM Quick and Easy if you want to make it totally painless ;
