First post, by gafland
I've been searching through the posts here for ways to get Quest for Glory I VGA to work with VDMSound. The solutions posted didn't quite work for me.
P4 1.8 GHz
Windows 2000
VDMSound 2.04
Sound Blaster Audigy
First off, extracted QfG into a folder. I try to run install.exe with VDMSound, it does, but I have no keyboard input. So far I've had run install.exe with DOSBox. I set it up for Sound Blaster for music/speech and to use XMS memory.
Then I install the sb16drv.exe in my QfG folder. I try to run hero.bat/scidhuv.exe with VDMSound but no luck. It sits there with a "Unable to initialize your audio hardware" error message. I've tried changing the Sound Blaster to IRQ 5 and just about every other audio option available.
The game does work with DOSBox but there are some graphics/sound timing issues and changing the CPU cycles doesn't seem to help. I've also tried PITSET but again, the same results.
Does anyone know what the problem seems to be or how I should setup Quest for Glory I with VDMSound?
