Reply 20 of 84, by [vEX]
- Member
wrote:VDMSound doesn't care about your soundcard, actually VDSMound should be detected by games even if you have *no* soundcard at all (weird, huh?)
Yes I know it shouldn't matter but seeing as I only have the problem I figured it has to be some hardware issue.
BTW, did you check the log file yet to see if you can detect any problems ? Cause as far as I could see it should work.
Antec P182B | Asus P8Z77-V PRO | Intel i5 3570k | 16GB DDR3 | 4TB HDD | Pioneer BDR-207D | Asus Xonar DX | Altec Lansing CS21 | Eizo EV2736W-BK | Arch Linux (64-bit/x86_64)
