Reply 20 of 33, by Nicht Sehr Gut
- l33t
Originally posted by Unregistered run it with the /W switch.
Already covered. It's in the problem child thread (along with the memory bug, etc...).
I got Death Rally to work using the batch file option (w/ nolfb), but when I exit the game, my video display is all "funky" and I have to reboot to clear it up. Any way to fix that?
Originally posted by Unregistered ...but when I exit the game, my video display is all "funky" and I have to reboot to clear it up.
Well it's usually related to your hardware...and we have no idea what that is as you haven't told us.
Odds are this is a video driver issue. You shouldn't have to reboot unless it's locked up your system. Have you tried going back to the desktop and changing video modes?
I've running an ATI 9700 Pro. I've tried various combinations of resolutions and color depths to no avail.
Originally posted by Unregistered I've running an ATI 9700 Pro.
I'm not sure that the Radeon needs NOLFB. Have you tried running it without NOLFB? You still haven't mentioned your OS. I'm guessing Win2K or XP, but you shouldn't have to reboot just to clear your video display. Just changing video resolutions temporarily should refresh the desktop. If not, logging off, then back on.
If you're on Win9x, then you should probably reboot anyway to clear your memory.
?? Is this "compatibility mode" you are talking about? If so, that only applies to Windows titles, not DOS.
Windows XP. Yes, switching resolutions seems to clear up the problem. However, I have to do the same process w/ or w/out NOLFB. Oh well, just a minor inconvenience. Thanks for your help.
?? That doesn't make any sense...
Yes, it’s my fault.
Originally posted by Snover ?? That doesn't make any sense...
I've seen numerous corrupted desktop display from DOS titles like this, but it's the first I've heard of on an NT-based OS.
In any case, if NOLFB isn't absolutely necessary, it shouldn't be used.
If you hit Enter right after the "Stone" logo for Solar Winds, you can actually skip the intro. However, the game freezes here as well.
Perhaps, maybe, it's trying to poll for input, but's not receiving it properly...?
Well, I'm not sure about Solar Winds I, as I don't recall having any difficulty with it (but I haven't played it through since back on my 286). Solar Winds II, however, has been giving me the same lock-up problem. I think I may have fixed it, but I'm not sure. The following post contains not answers, but evidence. Hopefully it will help:
I've tried the game in VPC, and in XP natively. No luck. I recently rebuilt by old 486DX2-66 -->
ATI Mach64, SB AWE64, 6gb HD (2 partitions: 2gb fat16, 4gb fat32), MS-DOS 6.2 and Win95b Dual-boot
The first time I set it up, I had the whole drive as a single fat32 partition, using MS-DOS 7 (Win95 OSR2). Solar Winds II still wouldn't work past the first encounter. I think the conjecture that it may somehow be related to digitsed sound may be in the right direction, as the first shot fired always locks it up. Note: I tend to skip the intro, having seen it before, so I was able to get into the game.
So, having that problem and a few others, I decided to wipe the machine and do a decent job of making an old-gaming machine and dual boot. I re-partitioned the drive, and tried running Solar Winds II under MS-DOS 6.2 on a 2gb FAT16 partition. Seems to work now. I got farther than I ever had before, no lock-ups.
I can't be certain that the partition had anything to do with it, but it's the only changed variable that I'm aware of. I've tried the game under MS-DOS 6.2 on VPC, so that's not it. It could also be the partition size, I'm not sure what size virtual drives I used in VPC. This wouldn't be the first old game to "seem" to run on non-FAT16 partitions, but not work quite right (Lemmings 2, etc.).
I wish I could offer an actual solution, but all I have is my observations. Hopefully these will come in handy for someone else. I know how helpful it is to read others' experiences trying to get these games working again.
I tried Death Rally today (WinXP + VDMSound Update 2) and it works, but ist waaaaaaaaaaaaaaaaaaaaaay too slow.
Like on a 386 SX25 (but I have an AMD 2500+ so its a bit disappointing...).
Originally posted by Deledrius Well, I'm not sure about Solar Winds I, as I don't recall having any difficulty with it (but I haven't played it through since back on my 286). Solar Winds II, however, has been giving me the same lock-up problem.
Oddly enough, I'm no longer locking up at the intro with DosBox 0.58. Intro works, so does combat, any attempt at communication seems to lock it up.
Well, it's appreciated, we're working towards a common goal here.
It's a picky one, for sure...
A good setup for old software, but Win95 on a 486-66 is torture.
Seems reasonable. I was able to run it in VPC (with DOS 6) and had the same lock-up issues bypassed by disabling Digital audio. Funny, as that is the reverse of the problem I had with DosBox 0.58
Well, previously, that wasn't an option for me. The intro locked, bypassing the intro caused a lock...
It's possible. I haven't heard of any FAT32-intolerant titles out there, but I figure there are at least a few (my main FAT32 problem was large partitions causing the Installers to "freak out").
Don't recall hearing about that that one...
That's the idea here...
FWIW, the next public release of DosBox should have it working properly...
If you enable the mouse, you can get around the communication lockup. Left mouse button progresses dialog. When Stone's dialog list appears, click the right mouse button to display the yellow highlighter, move the mouse to select desired dialog, and left click to activate.
I think there may be a problem with the mouse cursor not being visible, not sure. But disabling the mouse when starting Solar Winds does lock the game up in communications mode for me. Everything else seems to run fine though.
Originally posted by Unregistered I think there may be a problem with the mouse cursor not being visible, not sure. But disabling the mouse when starting Solar Winds does lock the game up in communications mode for me. Everything else seems to run fine though.
Good tip, but if you just can't wait for the next official release of DosBox, try one of the CVS releases. It seems to run fine (no communication/mouse issue).
