First post, by cytan
I have downloaded the source of VDMSound from Sourceforge and plan to try and port it to OS/2. Unfortunately, I cannot find any build instructions in the source. If you can supply me with the following info that would save
me a great deal of time:
(1) From your webpage, VDMSound is modular. I assume that the VDD init
part and hooks to the NT sound system (which I will probably have to rewrite for OS/2) is separate from the EMU* parts of the source. Therefore, I can probably compile the EMU* parts without too much changes to the source. If this is correct, can you point out which part of the source tree is the driver part and which is the emulation part, so that I wouldn't spend too much time trying to sort things out.
(2) Is there a build FAQ at all?
(3) Is there a white paper on VDMSound showing the software block diagram? This will greatly aid me in understanding what needs to be built
in the first pass.
Thanks for any info.
cytan
