First post, by ajs
Hi,
First, let me thank you for such a wonderful program -- VDMSound allows me to play the old DOS GCS called "MegaZeux" without issue, and I'm enormously pleased that you are still working on it.
However, I recently upgraded my Windows 2000 installation to Windows Server 2003 Enterprise and VDMSound no longer works perfectly. In fact, I originally believed that it was completely broken, but discovered that if I stopped VDMS from loading the game in "fullscreen" mode, I got a regular MFC error message which must have been obscured by fullscreen and thus caused more problems.
The problem seems trivial enough to fix, and it doesn't at all affect the execution of the DOS app once dismissed. It does, however, prevent me (at the moment) from launching DOS games in fullscreen, which is an inconvenience.
I have uploaded a screenshot of the error message and a VDMS.LOG at max verbosity. The log, however, does not seem to indicate any error whatsoever.
If this is non-trivial to fix, may I suggest that when "tip of the day" is disabled, it does not attempt to load that DLL. This is what appears to be causing the problem.
Cheers,
Alistair Strachan.
