First post, by aub84
Yesterday I was testing and it looks much better than any other glide wrapper.
Dgvoodoo is the only one that gives me a satisfactory result in image quality. No more washed textures!
Nglide, Glidos or Dosbox do not get the same result
It is not possible in any other wrapper?
Reply 2 of 28, by aub84
DosFreak wrote:
Best to ask the wrapper developers.
You can use any glide wrapper with DOSBox even dgvoodoo.
Unfortunately I have a pc with windows 7 64 bit and not work dgvoodoo.
Glidos + best control gamma = perfect glide wrapper.
Reply 3 of 28, by Glidos
Glidos has an adjustable slider for Glidos. I have W7 64bit and an nVidia card. I just checked that the slider is working okay and it seems to.
Anyway, the best way to avoid washed out colours is to use one of the TRX texture packs.
Reply 4 of 28, by aub84
Yes, I know, but do not get the same color / contrast / brightness with other glide wrappers, including Glidos.
The best quality in dgvoodoo:
http://i.imgur.com/OiJ2x.jpg
http://i.imgur.com/mYs5Z.jpg
http://i.imgur.com/xr8sp.jpg
http://i.imgur.com/v843f.jpg
Glidos:
http://i.imgur.com/bhObL.jpg
http://i.imgur.com/h8zUD.jpg
http://i.imgur.com/hTw4Z.jpg
http://i.imgur.com/fcpga.jpg
There is a big difference.
Reply 5 of 28, by robertmo
dgvoodoo screens are fucked up (check the waterfall it is just white...)
Reply 6 of 28, by aub84
Well, you can adjust the gamma to your liking, but the result will always be better than another glide wrapper.
Reply 7 of 28, by robertmo
hard to say cause right now it looks extremally shitty, it is just way brighter, has like very very low quality of textures (also water looks very very poor).
if you say you like it, say you like it, but don't say it looks better cause it looks way worse heh
Reply 8 of 28, by aub84
The textures are worse because in Glidos I use a texture pack and dgvoodoo uses de default textures.
I refer to the difference in the gamma control of the game according to the program you use, nothing more.
As much as change the value of gamma in Glidos, it does not improve the image of Tomb Raider.
PD: sorry for my english 😜
Reply 9 of 28, by Glidos
Can you post comparisons with both wrappers using the default textures? The comparison with different textures tells us nothing: some of the texture packs are darker than the default.
It does look like dgVoodoo might be magnifying the contrast. If so, that will give the image more punch, but will crush the blacks and overdrive the whites. Perhaps dgVoodoo has an adjustment for that?
Reply 10 of 28, by robertmo
in his previous post he said he can adjust gamma, so also please adjust gamma to normal setting for comparison of pictures too cause otherwise it would still tells us nothing:)
Reply 11 of 28, by aub84
Dgvoodoo:
Default Gamma (100%)
http://i.imgur.com/b3RbC.jpg
125%
http://i.imgur.com/c0udV.jpg
175%
http://i.imgur.com/QlrjH.jpg
Glidos:
Default Gamma (1.0)
http://i.imgur.com/lbaSl.jpg
1.25
http://i.imgur.com/SGWmS.jpg
1.75
http://i.imgur.com/lpfSp.jpg
Unfortunately I've noticed that the screenshots (with FRAPS) of Glidos not respect the original quality and are all equal. Possibly because the gamma control behaves differently from dgvoodoo, instead dgvoodoo screenshots are faithful to the actual game. I do not understand.
I can edit the screenshots of Glidos to resemble as much as possible to how I see the game with this wrapper.
as an example
1.0
http://i.imgur.com/5nYv3.jpg
1.25
http://i.imgur.com/RU1tB.jpg
1.75
http://i.imgur.com/VgDDO.jpg
would be an option to be considered for future versions of Glidos.
It goes very well to increase the contrast of the game and eliminates washed colors.
I am looking for a quality image like this:
http://i.imgur.com/RRKuq.jpg
http://i.imgur.com/NRACq.jpg
http://i.imgur.com/8I7HP.jpg
http://i.imgur.com/gA0hG.jpg
http://i.imgur.com/xKKgE.jpg
http://i.imgur.com/irO0b.jpg
http://i.imgur.com/uWRt4.jpg
Reply 12 of 28, by Glidos
I'll give it some thought, but the game isn't supposed to look like that. It's set in a cave. Where's the bright sun light coming from that would explain a bright high contrast image like that? The 'quality' you are talking about is the same kind of 'quality' that you get from an LCD TV set to Dynamic mode - attracts your attention on the shop floor, but doesn't give a natural image you can live with in your living room. But I guess it's something some would like.
The gamma control can to some degree accentuate contrast, but it's values below 1.0 that do that, not ones above 1.0.
Reply 13 of 28, by aub84
The PlayStation version is also more colorful and bright (Whites more whites and blacks more blacks.)
Probably the PC version was so colorless, but give it a plus in contrast would be fine, as does dgvoodoo, if everything looks very grey and colorless.
Reply 14 of 28, by Glidos
Yes, but that would have been displayed on your TV, which you had set the contrast and brightness to your taste.
It would be fine to provide that as an option, yes.
Reply 15 of 28, by aub84
Glidos wrote:
Yes, but that would have been displayed on your TV, which you had set the contrast and brightness to your taste. […]
Yes, but I've played with emulator on a pc monitor and is also more colorful and bright than pc version
Even in software version (PC) is more colorful and contrasted than the 3D patch!
I have observed that several parameters glide2x.ovl editing that might (?) changed, but the game does not work if I do 🤣
example:
GRGAMMACORRECTIONVALUE @
GRCONSTANTCOLORVALUE
Thanks
Reply 16 of 28, by robertmo
But check how it looks if you just start a new game and don't move, look at the dark wall. In all wrappers (except dgvoodoo) it looks like on real voodoo 1 and voodoo 2 cards.
But in dgvoodoo it looks indeed more like on software, but does it look correct? It looks strange in my opinion. In software mode it looked rather ok, but with dgvoodoo it looks just strange... as if colors were wrong (even with gamma 100%)
Reply 17 of 28, by robertmo
sorry that was a result of using D3D textures bit depth 16-bit.
Oh well, so software mode looks like 16-bit cause it is 16-bit and that is why it looks different 😀
Reply 18 of 28, by Glidos
I wonder if Glide uses a different colour space to the standard sRGB, and maybe dgVoodoo accounts for that.
Reply 19 of 28, by Glidos
aub84 wrote:
I am looking for a quality image like this: […]
I'm really confused now: those images that you say are what you want are from Glidos using a texture pack.
