RB3D continued
First post, by Glidos
OpenGL has something called the "shared texture palette" extension. I'm just downloading the spec now. It should allow all this paletted stuff to be done properly without any frame rate hit. It may even be easy to do.
Reply 1 of 146, by Winkle
Paul,
Did you ever get the full version of RB 3D to work?
If not send me an email maybe I can help.
winkle@gadrome.com
Reply 2 of 146, by Nicht Sehr Gut
Check the thread here:
showthread.php?s=&threadid=275
Reply 3 of 146, by Flybert
From end of other thread:
Sir Alexi .. I don't recognize that terrain , have you completed something cool with the terrain editor ?
Reply 4 of 146, by Unregistered
Kewl. Your work is highly appreciated.
Reply 5 of 146, by Hentzau
Nobody picked up on Alexi's first screenies, i've been wondering myself? I bet the AI love flying in those mountains. 😁
Reply 6 of 146, by VonHelton
I did!!
But, I assumed it was Alsase Region........(??)
Reply 7 of 146, by DeltaK
According to threads on various RB-Boards graphics corruptions still seem to be one of the remaining major issues. I still get them regularly, when aircraft or balloons are flamed. I would like to quote the following explanation from the Promised Land Website ( http://www.wingwalkers.org/jasta1/newplmain.htm ):
>>Quote<<
Graphics corruptions - Known issue with graphics in RB2 that sometimes corrupt during gameplay, this is due to the larger more detailed graphics that put a heavier load on your video card, and the routine that RB2 was written to communicate to your video card. In essence, RB2 was made to communicate texture management to Voodoo I, an older Voodoo II cards and will at times get "confused" and display wrong or corrupted graphics with newer Voodoo II cards or better.
Fixes;
None at this time, a few work arounds to the problem are as follows;
Change your settings properties for your 3D video card to limit texture memory to 2 megs (this may have an effect on some peoples framerates, for most though, this is the preferred work around).
Change your ingame screen resolution to another setting, and then back to your original setting.
Alt-Tab and task out of rb2, then Alt-tab and task back into the game.
For those that experience DTD's when trying to alt-tab in and out of rb3d;
Change your ingame screen resolution to a different resolution than that of your desktop.
>>unquote<<
Unfortunately the Alt-Tab function does not work on my sys when using the wrapper.
Reply 8 of 146, by WilliVonBill
I have noticed that with the current version of the wrapper, the occurance of graphic corruption or 'funky black tiles' appears to have lessened. When I do get tile corruption, it is limited to only a few tiles or plane part .bmps. In some balloon busting missions I've had no graphic corruption. This is certainly an improvement from my dedicated RB PC with a Voodoo 5500. Without limiting the texture memory to 2 Megs on the Voodoo, graphic corruptions would not only occur, but would spread until almost the entire landscape and a good deal of the planes would have a notably 'surreal' appearance.
I caution that this is on my machine, so the performance will certainly vary from PC to PC.
Reply 9 of 146, by DeltaK
I initially thought it's only an issue with my "old" GeForce 2 MX 400. However folks with a Geforce 4 seem to be "suffering" as well.
Check this thread: http://www.simhq.com/simhq3/sims/boards/bbs/F … TML/000490.html
tn_prvteye has posted a link to a very typical sreenie.
Reply 10 of 146, by Mahoney
Worth stressing that this only happens with 3rd party graphic mods that use larger textures than the ones that RB comes with by default; so if the developer of Glidos wants to reproduce the problem he'll need to install some 3rd party patches on his copy of RB.
A quick way to reproduce the problem:
1) Go to http://www.xs4all.nl/~rensg/terrain.html and click the click here to download all new 3d vol files: Note size = 13.665 KByte (13.7 Mbyte) link. Put all the files into the RedBaron3D\Data\3DPatch folder.
2) Download http://www.wings-of-valor.org/files/patches/flameout.zip from Wings of Valor and stick all the files into RedBaron3D\Data\Simpatch.
Now go and set fire to something - a hangar, balloon or another plane will normally do it. You should get the graphics corruption.
If this could be solved in the Glide wrapper, I believe that I would die a happy man... 😀
Rob
Reply 11 of 146, by Glidos
Pretty sure this is a bug in RB. It sounds like RB's internal database, holding which textures it has sent to the card, gets corrupted. As far as I know, 3dfx didn't suddenly get things wrong when they brough out voodoo2; they just started to produce cards with more than 2MB of texture memory which tickled the bug. Setting 2MB for the wrapper is not an opiton (at least at the moment) because that will cause frantic glide to OpenGL texture conversions.
It is very unlikely I can fix something in the wrapper if it happens on a voodoo2.
When I get the paletted texture stuff done, then the 2MB setting may be an option; we'll have to see.
Reply 12 of 146, by fperkins
I noticed that when flying a Campaign mission, I get slightly slower frame rates, and graphic anomalies (black tiles, etc.) than when I fly a "Fly Now" mission, in which everything looks fine. I disabled my Voodoo2 card, and have my monitor plugged directly into my 64Mb Geforce2 card. I noticed that the latest version of the Wrapper has the texture memory set at 16 in the OpenGlide.ini file. I'll try playing with that setting.
Falcon
Reply 13 of 146, by GoldFinger
Very strange indeed, years after I released OpenGLide I realized (thanks Stiletto) that it is still used and enhanced, I am very glad to know that.
I will go back working on OpenGLide with Glidos, so maybe we can reach more games.
But I need to say: Thanks a lot for all of you and specially Glidos for ressurecting an old project of mine.
regards,
Fabio Barros
Reason: thought I'd typo-fix my name...
Reply 15 of 146, by Stiletto
Yeah, forget about the Tomb Raider fans, I think the Red Baron 3D fans really pumped Glidos up and got it going!
do the Fandango!" - Queen
Stiletto
Reply 16 of 146, by Snover
Hey, Fabio, if you're at all interested, I can hook you up with a forum here for OpenGLide comments, suggestions, improvements, development stuff, et cetera. I hope that it would keep more GLiDOS-specific questions here and then the questions for RB3D et al Windows programs in your section.
Yes, it’s my fault.
Reply 17 of 146, by Stiletto
But they already have a SourceForge forum...
Oh, wait, so does VDMSound, but it uses us instead...
Heheheheh... never mind. 😀
*opinion* Is it me, or is SourceForge a bad place to have a "community"? A good place for file hosting, getting attention to your project from programmers, etc. but a bad place to build a "community"?
Stiletto
Reply 18 of 146, by Snover
No, I'd have to overwhelmingly say that SourceForge is NOT the place to make a community.
Yes, it’s my fault.
Reply 19 of 146, by Glidos
I've just uploaded another version of OpenGLide. SunGlare (and getting shot) should be okay now without too much of a hit on frame rate.
Hey this should be my last bit of lone OpenGliding. I don't know if everybody has twigged, but Stiletto has located OpenGLide's daddy. Suddenly, OpenGLide has a bright future.
