...a voice from the darkness.....
Paul, this new step is excellent. GliDOS is not "just a glide wrapper", and it's more true from this time. I tried this newest feature, and it works great! I myself never heard the PSX-soundtrack earlier, although I knew it has more audios. The musics simply rock... 😎
However, I also have a problem. This problem exists with both TR1+Gold, and it's an annoying thing. The game is running fine for about 10 seconds, and then it stops for a half second (the framerate lowers to about 25-26 FPS from 30 FPS), and then it's good again for about 10 seconds, and then it stops again, and so on... It's still playable, but these slowdowns are really annoying, and make harder to controlling Lara. It seems like when something disturbes it from the background. But it was okay with GliDOS 1.28, and before I updated my videocard and soundcard drivers. I use only PowerStrip what never disturbes it. I have tips though: I installed the latest Catalyst 4.8 driver (ATI Radeon 9000 Pro 64 MB card) and a newer driver for my Audigy1-soundcard - perhaps they cause the problem? Or I should try to change the ControlJudderFix? I have these tips right now, but if possible, I don't want to downgrade my drivers. So, if You have any advices, then just drop me with them, please... 😀 Thank You!
SYS "Still alive Ms Croft. You are resilient."
