First post, by pbjpb1
hi guys
I downloaded the unfinished business levels and installed the 3d/fx version as instructed here:
http://www.tombraiderhub.com/faq/tr1.html#installgame
but when I use glidos to play unfinished business it says i need that CD?? i have the tomb raider cd in the drive. do i need to buy the unfinished business cd or something?? thanks.
Reply 1 of 4, by noname
First of all, is it the PC version you have in the CD rom drive or is it the Play Station/Saturn version?
Reply 2 of 4, by Glidos
If you are using v1.33 of Glidos, the adjust dialog allows you to turn off the CD check.
Reply 3 of 4, by pbjpb1
obviously it's the PC version in the CD rom drive..why would i put the PlayStation/Saturn version in my pc?? anyways....thanks glidos, i do have 1.33 and turned off the cd check so it works now.
Reply 4 of 4, by noname
Because I've seen some people before complaining that they can't get UB to work with their PlayStation CD. 😜
