First post, by Opaque79
I mentioned this to Paul but we couldn't figure out the cause
Been playing around with Glidos again recently and "Inhibit Mode Change" causes some of the image to be cut off. Any ideas why?
https://i.imgur.com/1DhE3jt.png
System Specs
Gigabyte AORUS M B450 motherboard
AMD Ryzen 5 2700x CPU
Radeon RX 5700XT GPU
32GB RAM
Windows 10 Home 64-bit
Reply 1 of 4, by Glidos
Actually, I've just noticed it's a perfect square. I imagine what may be happening is that Glidos is trying to create a surface larger than is necessarily permitted under the DirectX9 API. Some drivers may allow it, others not. That's a guess, but a reasonable one. I can't remember if I pass errors into the log file. There might be something.
Reply 2 of 4, by Opaque79
Well, here is the psVoodoo log file if that will help out. The game image is showing a 1200x1080 area.
Wasn't sure what to put the file license as.
    psVoodoo.log
    1.83 KiB
    202 downloads
Reply 3 of 4, by Opaque79
Apologies for double post but I just noticed something.
As Paul said, it's a perfect square and measuring the image in paint.net, it seems that Glidos is trying to use a 1600x1200 4x3 sub area but my TVs native res is 1920x1080.
Why this cuts off the right side I don't know but that may be key to the cause
