First post, by rapasonic
hello , i have paid 10 $ and i have obtained code for unlock glidos on 02?01?2007.
Today spinning logo reappear now and then , when i change option normal to mipmapping in the menu in the game.
What can i do?
Excuse me for my english.
I am italian and ignorant person.
Reply 1 of 3, by Kaminari
You need a new unlock code every time you change some significant piece of hardware in your system. Did you install/change any specific device during the last two days? A new video card, a new sound board, a new hard drive?
Reply 2 of 3, by Glidos
Its best to leave that setting on normal. If you want mipmapping set it in the Glidos options.
But that doesn't quite fix your problem. If the setting is making the logo appear then unlocking went wrong somewhere. Probably best thing to do is play until you get to the later levels, where the logo will appear independently of that setting, and then go through the unlock procedure again. If you run out of your unlock allocation, I can add more.
