First post, by tizerist
i noticed that when i load my savegame in the first main room of the cistern, the framerate starts at 2, and rises to about 10-12.
especially if i use the look button.
this can't be right, surely? i know its an old game, but not that low.
its fine if shes facing a brick wall (27-30) but when she looks over the big chamber it suffers badly, not so much so without texture packs.
does anyone else get a frame hit this badly, and whats the best options to tweak to combat this?
cheers.
Reply 3 of 3, by Glidos
P3 666MHz might not quite have the grunt. The oldest machine I used to run Glidos on was a 400MHz Duron. That used to drop framerate when looking across a big room, although it wasn't too bad. That was before the days of TRX too, and the more detailed textures can only make it worse.
