First post, by zjm68
when I run Glidos, it runs fine, but the actual gameplay is in the upper left hand corner of and off the screen. The wallpaper is fullscreen, but the menu is small and in the upper corner. I have tried changing the resolution, reloading Glidos and VDM and tried the fullscreen option. I have also tried changing the screen size with the F2 and F3 controlls. Any help is welcome.
Reply 2 of 4, by zjm68
I installed Tombraider like I always do. Threw the disc in and installed with the install program. I have loaded and loaded Glidos after about 5 windows reloads.(over several years) I have never run into this problem before. I am using Glidos 1.4, Windows XP SP2.
