First post, by JA
I'm having problems w/ TombRaider Xtra.
I downloaded the title page and the 1st level, and installed them.
I modified the GLIDOS.INI file:
Selected: Tomb Raider
Executable: C:\Tombraid\Tomb.exe
ExeSizes: 873739
CDCheckFile: data\Level10c.phd
DosGraphics: Yes
VESASupport: No
ControlJudderFix: 1
Resolution: 2
FullScreen: Yes
TextureOverride: Yes
[SNIP]
and I can see that there's a Textures directory under Glidos, and it has a whole bunch of subdirs, each with a texture that I can open.
But when I run the game, I can switch between the original textures and "no" textures -- everything's just white! The main menu, btw, is just white behind the menu ring.
Specs:
Glidos v1.25
Tomb.exe is dated 6/1/1997
Gfx is Intel815, w/ latest (final) drivers.
OS is WinXP Pro
Screen res is 1024x768 but the messages in the Glidos window say 640x480 (??)
Any thoughts?
Thanks!
-Jeff
Reply 1 of 2, by JA
Sorry, I should've read through all of the old threads before I posted. The solution for the fellow with the Intel810 graphics worked for my Intel815 graphics (no surprise, as the drivers are identical).
I changed the glide2x.dll to the "old" version from OpenGlide_v007b4.zip and it works fine now.
Regards,
-Jeff
