First post, by djpotter@intergrafix.net
I,ve downloaded the installer for Tomb Raider 1 and Glidos v1.27, installed them and everything is perfect.
When I try to install Tomb Raider Unfinished Business with the same installer it says it cannot locade the Tomb Raider CD.
Also I can't find the tombub.exe file for use with Glidos.
Where can I get both the installer for TR1 gold unfinished business and the tombub.exe that is necessary for Glidos?
Reply 1 of 3, by Guest
Yeah i got the same problem i can run tomb raider with glidos but not unfinished business it says: CD not present place the cd in drive,and wait a little.if a splash screen comes up select exit.Then restart the game from glidos? I've not got a 2nd CD to use anyone got the correct tombub.exe or tumb3dfx.exe?
