First post, by sydjanus
crash's immediately upon either, and gives me a windows box for glidos with read failure. This is on XP with a dvd drive. I thought it might be a problem with the disc not being read fast enough, but the movies load and play correctly, and the failure occurs instantly. Anyone have an idea on what I could try?
Reply 5 of 5, by Glidos
This is very strange. If I remember rightly, Redguard uses Glide calls to play the movies. If you set up Glidos in windowed mode, do you see the movies play in a window?
Does it crash independently of whether you let the movies run or skip them?
