First post, by futurama rox
hi!
Is there a way to figure out what changed between the different glidos versions?
i see there is already a v1.28 ... is is worth installing ?!? what changed ?!?
some kind of Changes.txt ?
thanks for the answer...
Reply 2 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you can use some nice scripts to parse it for you.
take a look at
http://pcnwstage.phys.rug.nl/dosboxcvs.txt
this lists all changes since 0.61 (for dosbox that is)
I'm sure you can create something like that as well that is version based.
Water flows down the stream
