First post, by Unregistered
Greetings everyone.
I was wondering if there is a way to try GliDos with TR
3dfx demo ? I am looking in buying Tomb Raider but
before doing so I would like to see if the demo would
work with GliDos and VDMS on my machine (W2KSP3
on a Celeron 400Mhz + 400Mb RAM + TNT1).
Therefore, I downloaded TR 3dfx demo and glidos.
I modified glidos.ini to point to TR 3dfx demo directory
and I changed the file size of tomb.exe to the one
of the demo. Now, needless to say since I post here
it does not work. (Launch and die smoothly, quickly)
I then tried to launch setup.exe with GliDos (modifying
glidos.ini to point to setup.exe instead of tomb.exe
and modifying filesize). setup.exe stars then takes
100% of the CPU.
Is there anything that I need to do to fix this ? browsing
the GliDos smart group files section I saw in the 'Public'
folder the files Hmiset.cfg and Settings.dat. Do I need to
do anything with those files ? I copied them to TR 3dfx demo
directory without anymore luck in launching setup.exe or
tomb.exe ...
Any help would be greatly appreciated to experiment with GliDos.
Thanks in Advance.
