I tried Galaxians and Asterock.
Sound was heard through PC internal speaker only, nothing at all through the system speakers.
Here is the readme file for my Artis 738S1 sound card, however the setup program doesn't seem to do anything. No entries have been added to Autoexec.bat or Config.sys, they are both completely blank.
I thought VDM sound was supposed to be independant of hardware and drivers ?
Now I'm confused as well as depressed.
Marvin
4.1. DOS Installation
Before beginning the installation, please make sure that your hard disk has sufficient space (min. 4MB). Insert the Driver CD into the CD-ROM Drive.
1. Change directory to PCI audio DOS drivers folder (ex.
D:\DOSDRV) at DOS prompt, and type: INSTALL [Enter]
2. Type DOS utilities path you want to install the file in.
3. Program will expand the file to the path you've specified.
4. Install program will add initial drivers into AUTOEXEC.BAT file.
PCI audio DOS utilities instructions
* SETAUDIO.COM
DOS initial program
The following are the parameters format:
/Gx : x=0 disable game port, x=1 enable (default)
/Mx : x=0 disable MPU-401 MIDI port, x=1 enable (default)
/IOxxx : Set SB I/O port to 220(default),240,260 or 280.
/FMxxx : Set FM I/O port to 388(default),3C8,3E0 or 3E8.
/MPUxxx : Set MPU-401 MIDI port to 330(default),320,310,300.
