Reply 40 of 64, by aitotat
I somehow didn't even think the possibility that Line-IN mixer mode needs to work when SET BLASTER card is the one connected to another Sound Blaster cards Line-IN. Looks like some way to select the card is needed so I'll see what I can do. But since both are Sound Blaster Pro compatible, they should work without specifying the 'L'. That way it should not matter how they are connected.
Dual OPL should definitely work when SET BLASTER card is the left OPL card and right OPL card is the card connected to left cards Line-IN. If Left card is at 220h and right is at 240h, then "-fmr=a240l" should work. That is how I've done testing mostly.
There could be a bug that prevents Left OPL to be configured to be anything else than SET BLASTER card. I'll investigate.
I'll have to test Sardonic. I was supposed to but then forgot it. If it does mixer reset or any other adjusting to Line-IN volume, then make sure you use the -lock command line parameter. Otherwise nothing protects unwanted Line-IN volume changes and it must remain unchanged especially in the Line-IN mixer mode. Maybe I should force the -lock for dual OPL mode or at least protect the Line-IN volume even when -lock is not used.
