NVPatch - making UniVBE work on NVidia cards
First post, by wbc
This utility allows to use certain DOS VESA and Win3.x drivers on newer NVidia GPUs, such as Riva TNT family and GeForce 256 up to FX series (theoretically up to 7xxx).
Supported drivers:
  • SciTech Display Doctor (aka UniVBE) 6.53 and 6.7
  • Riva TNT/TNT2 Windows 3.x drivers, v 1.55 (untested)
DISCLAMER: THIS UTILITY IS PROVIDED "AS-IS", I bear no responsibility for any harmful or undesired actions or consequences caused by using it on your hardware, although the probability of such outcomes are extremely low (unless you are using some very very ancient VGA monitor unable to tolerate out-of spec timings). In other words: use at own risk :)
DOWNLOAD is in attachments, source code and latest releases are available in GitHub repository: https://github.com/wbcbz7/nvpatch-dos
Although built-in NVidia VBE 3.0 support is near-perfect and compatible with large variety of DOS software, it has a few shortcomings - like 15bpp modes being missing (required by games like Alien Trilogy in high-color mode or X-Men Children of the Atom), or lack of several low-resolution modes like 320x480 or 512x384. In the past, utilities like SciTech Display Doctor (also known as UniVBE) were popular choice for fixing VBE issues and providing additional features like linear frame buffer, low-resolution modes, etc. Unfortunately, support for NVIDIA graphics chips is very sloppy, and anything newer than Riva TNT is not actually supported. NVPatch hacks hardware detection routines and makes those utilities run on newer hardware. Additional side-effect is custom refresh rate stuff working again on late Geforce FX and newer cards :)
Known benefits over stock NV VESA BIOS:
  • more low-res modes: 320x480, 400x300, 512x384 and 640x350, in addition to already supported 320x200/240, 320x400, 640x400/480 and above.
  • 15 bits per pixel RGB555 modes added, in addition to 16/256color, 16bpp and 32bpp. 24bpp (packed RGB888) is not supported in hardware, though very few VESA applications require this and do not work at other bit depths, so it's not a big issue.
  • generally higher compatibility with quirky/buggy VESA applications.
  • flexible refresh rate and screen adjustment management (no UniRefresh/VBEHz and similar utilities required)
Known limitations:
  • only primary VGA output is supported! DO NOT try to use patched UniVBE on DVI/HDMI displays, as it will blank the display (and possibly crash the system) while attempting to set any VESA mode. Besides, DVI support under plain DOS on NV chips is far from perfect: image is blurry, frame rate is locked to 60fps and some games don't work properly, while running fine on VGA.
  • modes above 1024x768 are not tested and may not work properly
NVPatch supports both SDD 6.53 and 6.7 (DOS only). Personally, I would recommend SDD 6.53, and only if it does not work properly, then try 6.7
SDD 6.53
uses RIVA 128 support code, needs quite an intensive patching ;)
Known limitations:
  • VRAM size is limited to 8 MB
  • max. provided resolution is 1600x1200
Patch usage:
  1. Install SDD as usual
  2. Copy NVPATCH.EXE to SDD directory, and run it. Check if all files under SDD 6.53 description are marked as "ok", ignore others.
  3. If your graphics card has more than 8 MB of VRAM, run
    UVCONFIG.EXE -m8912
    CONFIG.EXE -m8192
    Else, run UVCONFIG.EXE and CONFIG.EXE without any command line parameters. If both runs succeed, then SDD is patched and configured properly.
  4. Run UNIVBE.EXE
  5. Run any VESA application (VBETEST from SDD package is a perfect match :)
  6. (optional but recommended) Run UNICENTR.EXE and adjust screen position for VESA modes
SDD 6.7
uses RIVA TNT2 support code, may have better GPU compatibility than SDD 6.53
Known limitations:
  • VRAM size is usually limited to 16 MB
  • unlike 6.53, doesn't provide certain low-resolutions VESA modes (namely, 320x200, 320x400 and 320x480). Since 320x200 VESA is used by some DOS demos and games, you have to use native NV VESA BIOS or SDD 6.53 for those apps.
Patch usage:
  2. Copy NVPATCH.EXE to SDD directory, and run it. Check if SDD 6.7 UVCONFIG.EXE is marked as "ok", ignore others.
  3. Run UVCONFIG.EXE, if it succeeds, then SDD is patched and configured properly.
  4. Run UNIVBE.EXE
  5. Run your favorite VESA application :)
Tested NVidia cards and GPUs:
Tested and working (more or less) fine on:
  • RIVA TNT 16 MB AGP (6.7 works out of the box, 6.53 needs patching)
  • RIVA TNT2 M64 16 MB and 32 MB, both AGP (strangely, while 6.7 declares TNT2 support, without NVPatch it does work only with TNT2 Ultra, judging by PCI Device ID)
  • Vanta 16 MB and Vanta LT 8 MB, both AGP
  • GeForce 2 MX200 32MB and MX400 64 MB, both AGP
  • GeForce 4 MX440 64 MB AGP
  • GeForce FX5200 and FX5500, both 128MB AGP (the latter has the infamous broken VBE3.0 custom refresh rate support in it's video BIOS, and it works again with SDD)
Does not work on:
  • GeForce 7600GS 256MB PCIe (blank screen upon any VESA mode set, goes back to VGA modes fine)
Windows 3.1 Display Driver
NOTE: unfinished, still broken, moreover, it's buggy even on a TNT itself (fonts corruption, DCI not working, etc.). basically you have to patch NV4VDD.386 file from driver package, then install the drivers as usual.
as usual, comments, suggessions, testings etc. are always welcome :)
--wbcbz7
Reply 1 of 20, by Falcosoft
Unfortunately I cannot confirm that this can work beyond Geforce FX. I have tested Geforce 6600 AGP and 6600GT AGP and none of them worked with patched 6.53 univbe.
The patched univbe can run without problems and vbetest also shows working univbe with VESA 3.0 8MB but none of the selected vesa modes gives picture. In most cases the monitor turns off but it can be waked by pressing esc (so no freezing happens just simply nothing is displayed).
I'm sad since I was hoping refresh rate adjustmenet under DOS with Geforce 6 cards (none of them supports it under DOS natively).
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 20, by Gmlb256
Did test with both TNT2 and GeForce2 GTS AGP cards on my Slot 1 computer and the patch mostly worked well in regard to 15bpp and low resolution VESA video modes. UNICENTR from UniVBE 6.7 is more stable when setting the position and refresh rates for each VESA video mode.
Unfortunately, Alien Trilogy's high color mode freezes the computer when using SDD 6.53. With UniVBE 6.7, it loads with the correct colors, but the screen looks messed up. 🙁
I suspect that it is due to the Display Window Control function (4f05h) not working as intended. Perhaps patching it or making a separate TSR that calls the native VESA BIOS directly could be used as a workaround (NVVBEFIX in the future? 😁).
Reply 3 of 20, by wbc
Falcosoft wrote on 2023-06-02, 23:24:
I had exactly the same issue with 7600GS, so I assume NV changed the inititlaization method somehow starting with 6xxx series. As a workaround, try running NVSDDFIX.COM before running UNIVBE.EXE, but I doubt that will do the trick; will peek at this issue later :)
Gmlb256 wrote on 2023-06-02, 23:35:
This one sounds weird as well, Alien Trilogy seems to work for me on both GF2 MX200 and FX5500 with patched SDD 6.53 (the other specs are Celeron 300A/i440BX/256MB/IDE CD-ROM/DOS 7.1 + UMBPCI + UIDE + SHSUCDX, TRILOGY.EXE is dated Nov 13 1996 19:41). First mode-switch is pretty long (waiting a moment at "Detecting card" message, then black screen for a couple of seconds) but then both copyright screen, introduction movies, main menu and in-game graphics work without hassle. Try booting to plain DOS + HIMEM.SYS + CD-ROM drivers, and run the game again.
this was actually the first idea I had :D
--wbcbz7
Reply 4 of 20, by Gmlb256
wbc wrote on 2023-06-03, 08:48:
Mine is patched to version 2.0, TRILOGY.EXE being dated Dec 23 1996 16:06.
Tried booting DOS with just HIMEM.SYS and CD-ROM support, still freezes the computer with SDD 6.53 after the passing the "Detecting card" message. 🙁
Reply 5 of 20, by wbc
Gmlb256 wrote on 2023-06-03, 14:30:
Tried booting DOS with just HIMEM.SYS and CD-ROM support, still freezes the computer with SDD 6.53 after the passing the "Detecting card" message. :(
installed the 2.0 patch, seems to work OK on my configuration :/ (UPD: tried on TNT2 M64, works as well)
If SDD is not loaded, vertical stripes are shown instead of copyright screen, and main menu colors are garbled:
The attachment photo_2023-06-03_22-07-25.jpg is no longer available
If I load the patched UNIVBE.EXE, then everything work as expected, with correct image:
The attachment photo_2023-06-03_22-07-28.jpg is no longer available
Does high-color version work on your configuration with cards that support 15bpp, for example S3 Trio/Savage?
--wbcbz7
Reply 6 of 20, by Gmlb256
wbc wrote on 2023-06-03, 15:09:
Those vertical stripes and bad colors happen in my case too on nVidia video cards without SDD/UniVBE.
The attachment Vertical Stripes.jpg is no longer available
The attachment Bad Colors.jpg is no longer available
Yes, it works without any problems on any video card that supports 15bpp out of the box.
Reply 7 of 20, by wbc
Gmlb256 wrote on 2023-06-03, 15:54:
Notice the overscan borders where the copyright screen should appear since I'm using a CRT monitor. Doesn't appear when it is displayed properly.
Can confirm the white overscan between "Detecting Video" and the copyright screen, but otherwise it seems to work for me (also, additionally tested on Cel1000A/i815/TNT2 M64). also, skewed screen on SDD 6.7 confirmed
I suspect there could be some sort of compatibility trouble with your machine in SDD 6.53 itself- does it crash the system when using with other non-NV cards?
p.s. by the way, I'm using SDD from univbe67.exe and sdd653-d.zip from this archive, if that makes sense :)
--wbcbz7
Reply 8 of 20, by Gmlb256
wbc wrote on 2023-06-03, 18:47:
No, Alien Trilogy with SDD 6.53 loaded doesn't freeze the computer with non-nVidia cards.
I'm also suspecting that there could be indeed a specific compatibility issue with my computer when using the RIVA 128 support code with this game. 😒
Reply 9 of 20, by badmojo
Thankyou very much for this OP, this is something I've been wanting for a while now so was very excited when someone directed me to it. I was limited to a Riva 128 card because I use UniVBE with the DOS version of MEKA, but that meant my Win98 3D capabilities weren't great.
I tried it with a TNT2 M64 PCI and it works very well, so now I have great 2D and (pretty) great 3D in one machine.
Reply 10 of 20, by digistorm
I am also very glad with this patch. I use a GeForce 2 MX and it can’t do 15 bit video modes and lacks the low res modes 400x300 and 512x384. Now I don’t have to swap video cards when I want to use those resolutions.
The only minor thing (but it was probably assumed) is that you have to register the software first (it is free) otherwise it will keep nagging you about it. If you do it afterwards the patch is undone.
Reply 11 of 20, by badmojo
I had an interesting result when using this patch with a PCI Geforce4 MX440. When using Univbe 6.53 it worked as expected, but with v6.7 the card's default refresh rate was ~133Hz! I tried to use UNIRFRSH to set it to something more reasonable, but that only increased the refresh rate, even if I specified 70 Hz.
Not a big deal and it's unlikely anyone cares, I just thought I'd mentioned here.
Reply 12 of 20, by AlexZ
This doesn't work on GeForce FX 5600 and AOC 9GlrA connected to VGA port. I tried both SDD 6.53 and 6.7. There is a problem with setting proper refresh rate. UNICENTR.EXE tries to set too high vertical refresh rate regardless of my selection and monitor doesn't allow it. A dialog appears with horizontal and vertical frequency where vertical frequency is like 240Hz which is too much. It happens even if I select 60Hz or BIOS default regardless of the resolution.
Unirefresh 1.42 works correctly as it allows to configure monitor parameters and resolution refresh rate explicitly.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 13 of 20, by AaronS
AlexZ wrote on 2025-09-13, 18:13:
Hello, I'm trying to get this to work with Alien Trilogy like the above posts, which I believe is 15bpp (there's also a 256 color mode which works fine). I followed the guide in the first post and also tried your method with unirfrsh, unfortunately I can't get a signal when I launch the game, however I can hear the game running so the system isn't locking up at least.
My card is a Quadro FX600 with 2 DVI out, although I believe when using a VGA adapter into a VGA monitor it knows its in "analog mode". This uses the same NV34 chip as the FX5200 and FX5500. My monitor is an "AOC I2490PXQU" and the manual says:
Horizontal scan range 30~83KHz
Vertical scan range 50Hz ~ 76Hz
So I put those into unirfrsh, set the "Automatic Setting" to 76Hz, save, then load unirefrsh after SDD 6.53, but still no signal. I want to eventually connect this to my retrotink 4k but I don't want to risk damaging it until I can get this working on my monitor first. Did you mess with any of the individual settings in unirfrsh? I noticed after I load SDD 6.53, 15bpp modes show up. When I press T in unirfrsh it always says "error calculating the refresh rate", even without loading SDD 6.53, none of the tests work.
One other thing I did notice is when loading UniVBE in SDD 6.53, I get:
Linear framebuffer: 3328MB (Before) | Not Supported (After)
This is with Jemmex and not using the standard Himem / EMM386.
Reply 14 of 20, by AlexZ
I used Unirefresh 1.42 only, without SDD. You are using them together. That may be the reason it doesn't work.
AOC I2490PXQU is a cheap LCD so there is no need to set refresh rate.
Reply 15 of 20, by AaronS
Yeah I think I need SDD though for the 15bpp thing, without it, 15bpp modes don't show up at all under unirfrsh, never mind then.
Also saw the same person made a 16bpp > 15bpp application and unirfrsh shows t15bpp modes now, but Alien Trilogy remains green.
EDIT: Tried all the above with a GF 6200 PCI from the VGA out (incase it was the Quadro FX600 DVI ports not actually "running in analog"), still no signal with SDD and green Alien Trilogy with vbe15bpp + unirfrsh. Maybe its iffy with PCI cards?
Reply 16 of 20, by elcrys
Just for the record I was able to "fix" my Quadro4 200 NVS 64MB PCI with the patched SDD 6.53 (Quadro4 200 NVS 64MB PCI (NV17 based) - poor VESA compatibility). I can also confirm that you need to use a VGA adaptor as digital DMS-59 causes a black screen in VESA modes. Still a great success for DOS games!
Reply 17 of 20, by AaronS
I looked into this again after acquiring a cheap S3 ViRGE, which "just works" of course. Firstly, Toonstruck was a game that never really worked "out of the box" with my Nvidia FX600 (No SuperVGA chip detected error message), that game uses uniVBE in its install directory. After NVPATCH'ing SDD6.7 following the guide, copy and replace UVCONFIG.EXE in Toonstrucks folder and then run the game as TOONSTRK -B (-B disables double buffer to the video RAM, without this I noticed I was getting double clicks in the game), the game works perfectly now, just like with the S3, but the output is sharper/cleaner)!
The attachment TS.png is no longer available
Tried Alien Trilogy again in 15bpp mode, and now I get correct colors but skewed screen like someone previously mentioned:
The attachment AT.png is no longer available
I think SDD6.53 would possibly work however that doesn't seem to work with this card and/or motherboard at all (AM3+/AMD970/Phenom II).
I wonder if it works better on an Intel system in general, sadly I cannot test this currently, but perhaps that might give better compatibility. For now though I have the S3 to fall back on.
Reply 18 of 20, by DoZator
On GeForce 6\7, this method works (to a limited extent) in conjunction with UniRefresh, but it requires some additional steps. After a black screen appears in the game, you need to switch from VGA port No.2 to VGA port No.1 (the card usually has only two combined DVI-I ports that support VGA). The computer itself, UniVBE, UniRefresh, and the game must be initially launched on port #2. This allows you to set, in my case, for example, "1024x768@120hz" or "800x600@120hz" in MS-DOS mode. This works only for "VGA" connections. At the same time, not all supported frequencies are available for VESA modes (as is the case with NV3X or lower), but only those explicitly listed in the "Standard Timings" section of the monitor’s EDID for the VGA port (in my case, only 60Hz and 120Hz are specified there, so apparently only those are available). 640x480 and lower resolutions work at 60, 70, and 75Hz.
Probably, in the 6/7 series, NVIDIA strengthened hardware protection and began to rely more strictly on data from EDID (in order to provide additional security measures due to the upcoming large-scale migration to LCDs, which at that time were often connected via VGA but did not support wide frequency ranges, unlike more advanced CRTs). And the fact that the image is output to the wrong port is most likely due to certain changes in the design of the card itself (which, naturally, the 2002 UniVBE is not required to be aware of). On the other hand, this example clearly shows that in the 6/7 series, everything necessary for changing screen refresh rates under DOS via a VGA connection is still preserved at the hardware level; it’s just that you need the right software that would fully support these functions, taking into account all the nuances of later designs and other features of the NV40+ (such as on-the-fly EDID data redefinition or some kind of control over this function - so that the card receives the necessary data without reprogramming the EDID or using intermediate emulators). Or perhaps it’s enough to properly edit the vBIOS so that the card relies less on data from EDID and more on third-party utilities (typical behavior for many NV3X or lower-end cards).
As for DVI connectivity (on the 6\7 series), everything remains the same - editing the monitor’s EDID (the "Preferred Timing Block" section) and then flashing it using PowerStrip (or a similar tool), or using a hardware EDID emulator (which is more versatile). Nothing else has been devised yet.
Reply 19 of 20, by DoZator
DoZator wrote on 2026-11-08, 14:06:
But it’s still kind of crooked somehow. A more detailed examination using the method mentioned above allowed me to configure "72Hz" and in the monitor settings (in the information about the incoming connection), it now shows the frequency as "72Hz", but when I test this in real conditions using "Quake I", the image still moves in jerks, just as it did before, at "60Hz". At true "72Hz" (when connected via "DVI", for example, in combination with an appropriately configured "EDID" or when using NV3X+UniRefresh+VGA), the image in "Quake I" looks smooth at "72Hz", provided that "WC" is enabled. But here the image is very jerky, and this clearly shouldn’t be the case. The result of running "timerefresh" matches the enabled "WC". The tests in the "UniRefesh" settings program itself show some crazy results - 575hz\440khz. Perhaps the utility itself is acting up here and producing some weird output. Although, judging by the shaking of the image in "Quake I", it’s quite obvious that something is clearly not working the way it’s supposed to. But what exactly? And how can this be fixed? The previously suggested "NVSDDFIX.COM" has no effect on this situation.
