First post, by DosFreak
https://github.com/vogonsorg/ProxmoxDrivers
This repo is specifically for drivers and driver related software to enable a user to easily acquire the latest working drivers for their chosen OS. This repo will ONLY be for the latest working drivers for Proxmox devices AND passthrough devices and NOT a repository of all driver versions or drivers for all devices that can be used with passthrough.
I've decided to upload what I have otherwise I never will. This is mostly complete for NT4/98SE,2000+. Needs work for the remaining operating systems.
This repo doesn't contain modified OS files. AFAIK, legally it would have to be a patcher or an xdelta. So for instance if wanting to run XP on Q95 instead of 440fx then distributing ACPI.SYS from another OS or compiled from leaked source wouldn't be posted on this repo.
For what I've done so far I'd like to create issues in this repo for what I've encountered, add to the readme the list of emulated hardware and settings for each OS as well as commands needed to remove hardware from the config that's not shown in the gui, etc. Possibly blank templates as well with instructions on how to load them.
Make your games work offline
Reply 1 of 2, by DosFreak
Messaged the following for their thoughts:
FrankensteinTech
Re: Example/How To: DOS/Windows 98 Virtualization+Passthrough (over Thunderbolt!) with Proxmox (QEMU/KVM)
Ruthan
KVM(QEMU) Win98 videocard passthrough.I finally got it working- with full 3D API support Quake III 1600x1200 90+ FPS!
Reply 2 of 2, by DosFreak
Driver candidates
NVIDIA
NT4
71.84 - Disable NVIDIA Driver Helper Service
98/ME
45.23
2000
258.96 (GeForce) - Disable NVIDIA Driver Helper Service
261.19 (Quadro)
2000 (BWC)
Nvidia Inspector 1.95.9
359.06 - Do not install Audio driver.
XP/2003 32bit
NVIDIA Profile Inspector 1.9.7.3
355.98 (scaling) w/ HD Audio v1.3.34.17
355.98 (scaling) w/driver pixel clock mod for higher refresh rates on HDMI w/ HD Audio v1.3.34.17
368.91 (No scaling) w/ HD Audio v1.3.34.17
XP/2003 64bit
368.81 (likely no scaling) w/PAGE_FAULT_IN_NONPAGED_AREA nv4_mini.sys fix for BSOD for dual-monitor
XP (OnecoreAPI?)
Vista/2008
365.19
Vista (???)
732bit
391.35
764bit/2008R2
474.11 (no mod needed)
474.89 (disable signing)
7 (???)
8/2012
10 32bit
391.35
